I just purchased a new 2021 Silverado 1500 LT and was looking under the hood at all the stuff that has changed since my 2006 1500 LS days. I see a hose that seems to have some coolant on it  - maybe an over flow but could not find anything in the manual so hoping someone can help me understand what this is for. See picture 109832678_Mysteryhoseundercoolantsurgetank.thumb.JPG.fb16323f1d2752a3bfaf74a1466d3b48.JPG
More than likely an overflow. Coolant needs to have somewhere to go in case of catastrophic meltdown, otherwise, that reservoir, hoses, and engine become bombs. The weakest link would explode first.
Thought that may be the case ..trying to figure out all the new stuff still... and what to keep an eye on. thanks
I did a bit but felt like it had some coolant moisture on it and does seem to bend up under the tank ..need to look closer as I would have thought it would have out let near cap but do not see it.
Looking at the part diagram its part of the tank so probably some sort of coolant vent hose/overflow hose.  Looking at the 3.0 diesel tank it has one too.  The hose goes up into a nipple on the bottom of the tank.
ACDelco 84645616 Engine Coolant Recovery Tank
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
