My whipple e85 small cam 5.3 truck made 585. Bought the lt5 throttle body off rock auto and had my whipple adapter plate machined by myself. Gotta say night and day difference with 8mm gain. I had the l86 87mm TB before making 585 on E. Bit today without tuning the truck woke up. Just letting yall know the gain for power and throttle response is a must. Boosted boiz that is. Not sure on NA
Whipple adapter plate modded from their factory 91mm bored to 95mm to match the lt5 tb. I reamed the holes with a carbide burr with large flutes to accommodate the aluminum cuts. Overall spent about $160 on tb with 5%discount from rock auto. And my expensive machinist for $70 on the bigger bore match lol. Whatever I wanted it done asap
 But totally worth it. Before i could feel the choke with l86 tb (87mm) but after the quick bolt on it was power on tap. As soon as I left the shop bam! I felt like the thing had a pedal commander without the bad reviews. 8mm makes the difference ladies.
Edited by Noizyboy
Added info
Yes multiple dyno’s on the vettes and camaro forums confirm that throttle body has real world hp gains.
I’m sure you see a more noticeable improvement with your supercharger.
Edited by truckguy82
I'll post more pics for those who are wondering about slapping one on. But yeah just saw last night some folks gaining 15-35whp 10-40tq.
From what I've seen the bore is way to small for the lt5 to match to the l83 or even l86. Lt1 as well will need alot of material to be removed to match. I have all 3 TBs (lt5,l86,l83) and not sure if the l83 and l86 are same bolt pattern
L83 TB bolt holes about 97mm apart
L86 TB bolt holes about 104mm apart
This is the MAC bit my tool guy had on his truck and worked effortlessly. PN#98660 1/4 diameter.
  • 2 years later...
Hey just a quick question! I have a 5.3 with a whipple 2.9 and I have tried two ported lt5 throttle bodies and both will not work correctly so I'm running my stock throttle body still unfortunately but still made
550whp! Any tips on how you made yours work, anything special while tuning? Thanks!
Did you changed the intake pipe also? If you did and the ID is different, you’ll need a new tune. The TB alone shouldn’t be too much of a difference.
I actually did change that to a 4" id from factory which is 3"ish if I remember correctly including where the MAF is located and the shop said they corrected for that while tuning for the cam, lt4 fuel system smaller pulley!
What was the problem with the Lt4 TB? Idle? Part throttle? WOT?
Well at idle it was very irregular and was constantly hunting up and down and when you tried to rev or accelerate it was very slow! I got it from Soler performance throttle bodies and the guy has been super cool but he said he's not sure what I could do either!
  • 10 months later...
On 3/26/2021 at 12:10 AM, Flip07AWD said:
My 2015 All Terrain 6.2L just started throwing this code sadly 2 months out of warranty.
Where you able to get it covered under the special warranty?
I didn’t know they put a 6.2 on an all terrain I have an all terrain too but I have the 5.3
I have a 2017 Silverado 1500 with the 5.3 engine.  I had the DOD delete done, installed a GPI stage 2 cam, and had the L86 intake manifold and throttle body installed at the same time.  The truck ran like crap when I got it back.  I had it dyno tuned and what a difference!
    • I see where you’re going and I can appreciate that. Statistics can be misleading because of the word average. They say statistics show the average cost of a new vehicle is about 50k. The average monthly payment is close to 1000 dollars a month. That’s statistics for you. I know very few people who pay that.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
