I have a 2012 Chevy Silverado 1500 with the 6.2L. My voltage is 14.45v running around town but when I drive it for long distances or I let it idle for 10 minutes or more it drops to 12.67v and stays there. Yesterday I drove it for an hour and it dropped to 12.67v got to my appointment and when I came out 45 min later it said start vehicle battery low so I ran it for 20 min and shut it off and about 2 hours later it was still at 12.67v. I have put a 160 amp alternator on it from gm this is my 4 or 5 alternator. Any ideas?
Edited by Boomer1974!
Make sure the belt tensioner is up to snuff.  A loose belt can cause all sorts of issues.  Also make sure your terminal connections are good and clean, take them off and check the inside where it meets the battery.
21 hours ago, Boomer1974! said:
Thank you for your reply but those have already been checked and secured and tensioner is good.
considering you have replaced this alternator 5 times, you might want to get those rechecked.  Alternators have a built in voltage regulator for how much amps they put out, so very little on the truck body side can effect its short life span that you are experiencing. A dead short is possible,  or a parasitic draw but I wouldn't expect that to ruin your alternator.   You can try to remove a fuse at a time of non essential things like heater or ac, radio etc and see if this helps with your issue. If it were me based on how many miles you have run, and the amount of alternators you have put in,  I would replace the belt tensioner with a new one, if it doesnt change your issue, take it back.
The computer controls the output of the alternator and it seems to me that you need a new battery regardless of how it tests out.  These computer systems don't take kindly to aftermarket parts so make sure to use GM OE or ACDelco Professional parts.
Is your Silvy an NHT with 3.73 gears?
1 hour ago, Boomer1974! said:
Swathdiver it is a 2012 Chevy Silverado 1500 crew cab with 6.2 L  with 3.73 gears with a 6 in lift 325/60R20 BFG MT
My daughter just bought one; loves the 6.2 and NHTs 3.73 gears and it has a Zone 6.5 lift running 35x12.5x18s with Nitto mud tires for now.
Curious, what kind of mileage are you getting and did you recalibrate the speedometer?  She averaged 15 mpg on the highway on 91/93 and gets about 9 mpg burning straight E85 in mixed city/highway driving around town.
ProComp 6 in I bought the truck last year already lifted it is a Tuscany conversion. Not sure on the calibration of speedometer. I am going to put a McGaughys 7-9 on it in about 6 months I am getting around 12.9-13.5 on the highway running 87 just switched to 89/91 so will have to get back with you after I run it for a bit.
Swathdiver I drove to a town 14 miles away last night and I was getting 15.4 mpg with switching to the 89 octane. Taking it to get windows tinted on Wednesday so we will see what kind of mpg I get then. The shop is about an hour away and then I will be driving to my daughters game and then home so I will be putting some miles on it then. Will keep you updated.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
    • The cure for facism. https://imgur.com/gallery/cure-fascism-9DH3bHs
