Long story short stock truck will not start from time to time.  Finally did not start first thing in mornings three days in a row so its at dealer now.  Any one else had this problem, no trouble codes stored.  Tech has seen draws on batteries a few times but it stops before he can isolate it.  Any help would be great, driving a Dodge every day is killing me!!!!  :jester:
  • 2 months later...
Sorry that it has been so long to reply to this, both batteries were replaced in January.  The dealer kept it for 4 days and could not find the problem.  They said it was the air ride drawing the battery down, so every night I would disconnect it from the battery and also unplug my Edge CTS and for about a week it started every time and then one day when I needed to leave work early with them disconnected it would not start.  This has been going on for 5 months now with the random not starting I have a jump box that will start the truck every time.  The latest now working feature is the light sensor on the dash was lit up red!!!  And today even when it was jump started I would have to tune the radio, the presets would not work but now the radio is totally quite, with the volume turned all the way up it has no static?  I can use apps and it will play, the turn signals click the seat belt alarm goes off, I can blue tooth my phone and it plays?  I'm at a loss and the Tech can only say "I've never seen this before"  MAY DAY MAYDAT!!!!
  • 4 months later...
That red light is part of the anti theft system that activates whenever you lock the truck. It does disable the radio and other ckts. It is activated when the truck is unlocked with something other than the key or fob. Sounds like that may be your problem, not the air ride.
I finally think the problem is fixes!!!!  Two weeks ago, I noticed a strange smell in the cab, I looked around and saw a cattle feed lot and thought oh thats the smell.  I went on down the road and stopped to shop at a Home Depot and I noticed the smell outside the truck and no feed lot.  Couple days later drove the truck and had to walk in front of it and noticed smoke coming from underneath the hood, popped the hood and the battery was smoking!!!!  Replaced both battries again ( This time on GM's dime)  and it has started everytime I wanted it to!!!  :jester:
  • 5 weeks later...
No matter what brand or source, new parts, including batteries can sometimes be bad or have early failure.
Missed this post earlier.
Glad to hear you got it sorted out.
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
    • Djannoyed was a one hit wonder. Posted and disappeared.
