My 2021 randomly came without the multipro tailgate.  I can wait for one to come in but .. is it actually worth it?  Since I'm 5'2" and I need that hand hold in the side rail to help me in and out of the bed . .I was thinking maybe I do need that tailgate simply because the tonneau cover the dealer put on, covers half of that hand hold .. lol.
Yes. my Denali came with it, and I thought to myself at the beginning - what a gimmick.
Since then - there isn't a time that I opened my tailgate and did not use the multipro. the killer feature - being able to stand closer to the bed when loading or unloading - just that is worth the whole thing. I also ski a lot, and using the built in bench to change to ski boots.
i considered the multi flex and do like being able to stand closer to the bed for loading and unloading and the load stops but i decided on the standard tailgate because i didn't want to give up the power up and down feature.
Yes - You want it, especially at 5'2". I am about 5" taller and I use it just about 100% of the time, and oddly enough, have never used the assist bar. In fact, I am thinking of removing the bar all together. With the multi-pro, I can simply step up into the bed at any time.
Like many, before I owned one I thought the multi-pro was a gimmick.  I use it all the time and with a truck this tall I would not want one without it.  Just like 99NCAA, I drop the inner gate about 100% of time to get closer to the bed, or to quickly drop the step to get in/out.
I'm not one to leave a hitch installed when not in use, so that issue is not an issue for me at least.
same here.....mine came with it and although i am in construction thought i wouldnt use it.....I was wrong i use it alot, wouldnt buy another without now
I thought this would be a good place to ask this, since you guys all use these tailgates heavily, you'll have good insight.
I just got my 2021 last week and it has the MultiPro.  I like it so far, I didn't really know what to expect.  I'm coming from a ford with the pull out step.  I never used it because I was too impatient to pull it out.  The multipro is so automatic, I'm using it a lot.
The question I have, is what is the best way to close it once deployed?  It seems like if I want to close the dopdown section first, it is a 2 handed operation to not have the main gate go up.  So, I've been grabbing the drop down and kind of closing all at the same time, which is fine, except it seems I'm always grabbing the painted section between the handle and the top trim.  I can only imagine that will start to scratch and gouge depending on how filthy I am.
How do you guys do it?
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 721 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
