25 minutes ago, Yfz43gmc said:
I was told to buy the nittos but up in Manitoba, I just Didn’t trust them for the long & brutal winters we have up here.
Our roads and highways are in terrible shape. We have potholes big enough to take up residence in, and our snow clearing is not always done right off the hop. I needed something that I could feel safe with in the winter. I’ve had previous experience with the At2 and I liked them. My husband had Nitto trail grapplers that were not a great endorsement. They cupped and wore out rather quickly.
the Toyo At3 were i stalled on our tail end of winter and I got to test them in a few blizzards and decent snow dumps and with the icy spring thaw/freeze and I was really impressed. Traction was quite shocking at how good they actually hooked on acceleration and did not slide in braking. We have a couple of intersections here they get pretty polished by yahoos ripping out of the local Canadian tire, and it’s a sheet of ice around that corner.
my truck came with the duratracs and the low speed him drove me bonkers and they were useless in icy conditions.
the Toyos are not as aggressive looking as I would like, but I need tires that handle well in all conditions and these fit my needs best. And I went down in rim size and up on rubber to compensate best I could looks wise. I took a stab in dark and got the 285/70/17 and no rubbing, pretty sure the 305 would require trimming and/or cutting as it is close at full turn.
No one here seems to run the wildpeaks but maybe its a location/availability deal???
Great review 👏   if you had access to wildpeak at3 would you get them or still stick with at3?   Are the wildpeak more aggressive look then the at3?
On 6/18/2021 at 2:28 PM, Chad Kauffman said:
Would you recommend the toyo open country at3?  Or should I get the Falken wildpeak at3?
Zero experience with either so can’t say. Sorry.
7 minutes ago, Chad Kauffman said:
Part of me want nitto ridge grappler. Your thoughts?
If you ever drive in snow or mud I would steer clear.  If you’re on dry road they are fine and look cool.
Yeah I drive in snow and ice roads if we get a storm.   I'm from PA. But snow I mean roads are plowed  I'm not driving into snow banks or through snow piles. I never drive in mud
If you look at the tread on the tires you’ll see the ridge grapplers have far less siping. It causes them to not have the same traction in snowy conditions as the at/ko or duratrak.
I cant say which looks mote aggressive as I have not seen wildpeaks in person. But hopefully pictures come through of my Toyo At3 mounted. Not very aggressive looking but the tradeoff of handling/ noise elimination justified for myself
Very nice.  I get mine mounted Saturday.. 275 60 20. $1100.00
 Toyo Open Country AT3 and Nitto Ridge Grappler are the best choices for car dealers and buyers. Toyo Open Country AT3 has made it well-balanced with its chunks-and-cracks-resistant components. Most distinctly, its symmetrical pattern, as well as its voids, are all evenly distributed. The dynamic hybrid pattern of Ridge Grappler makes it to be so easy and quiet for on-road trips. These tires have good traction due to their tread featuring zig-zag patterns, a unique feature of Ridge Grappler.
Edited by lakinzo
2 hours ago, SAINTS 504 said:
Nittos FTW
Nice! Like how those tires look.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
