Hey Guys! I have a New 2021 Sierra Denali 3.0 Duramax. Love it so far and have been sorting it out nicely. I have had 3 of the previous generation truck. I always mount LED rear backup lights on the rear bumper as some of the places I race have no lights in the parking lots. In the past I pull 12V power and the reverse light as a trigger wire for the relay for the lights, off the trailer wire connector. Well.......this 2021 does not light up that plug unless the trailer is connected. Once you plug in the truck recognizes a trailer is hooked up. For some reason there is 12V that is on but none of the other wires are live till a trailer is hooked up. I thought something was wrong so  hooked up the trailer and boom everything then works and the display states trailer hooked up.  So...I can get the 12v for the relay but now I am trying to find which wire on the rear tailight harness is the reverse lights? Appears to be the light green one I think?? But this truck is all LED and its a very light gauge wire. Does this truck have a LCM like the german cars.? Light control module. Will it sense a larger load and screw up something?? Pretty common with german cars. Also afraid to mess up any modules? I have wired 10 different pickups this way but the new generation is definetly different! Any advice for a trigger wire on relay?? Is that much of a load to the relay??
Thanks
Edited by seamus2154
No one knows if this truck has a module running the trailer plug or rear taillights ?? Nervous to just use that light green reverse tailight wire as a trigger for the relay and destroy a module.
This is the stuff I hate about my German cars, cant mod a thing without a computer problem.
I have a tailgate LED light bar, and light strips that use power directly from the reverse lights. I will have to see what wires I used since it's been a while.
Not sure if they're the same as my 2020 RST though.
I went another route since I didn't want to take a chance cutting and splicing wires.  I bought Curt Industries T-connector 56584 and flat wire extension 58531. The T-connector t's into the big bumper wiring harness behind the bumper and the extension plugs into the T-connector. I then connected my aftermarket reverse lights to the extension. This way nothing in the truck's original wiring is altered.
This setup also gives me the option to connect other running lights or turn signals using the remaining wires on the extension with no worry about the trucks original wiring.
https://www.curtmfg.com/catalogsearch/result/?q=+56584+Trailer+Wiring+Harness
https://www.curtmfg.com/part/58531
I bought some cheap Nilight lights from Walmart in case this idea didn't work so I've got less than $75.00 in this setup. The lights are plenty bright but don't wash out the camera at night.
Thats a great option for not cutting the wires, thanks. I dont know if the 2021 Sierra Denali is different that the trailer plug is not active other than a 12V when a trailer is not plugged in. None of the pins light up without a trailer plugged in. Never came across this before. I assume its due to the new trailer package and interaction with the screen?? So if that plug is not live I cant see how the T would work on the 2021???? As soon as the trailer is plugged in, it pops up on screen and prompts for the light test which works perfectly and all trailer lights work. Unplug it and test those pins and nothing but the 12V works. There is a schematic on the plug cover if you look. So i am assuming its going through a module????
Thnaks for the input
There are some electrical plugs up by the spare tire that allow for the Putco blade tailgate led lightbar to work.  I have that accessory and did the install.  It was plug and play.  The lightbar does illuminate white when put in reverse.  Perhaps you could create a harness to work between both ends of the plugs.
Thanks
This Is what you want to use. Its plug and play with reverse out.
https://www.putco.com/529005
Wow, this looks perfect! I put in 2021 and it states it does not fit a 2021 Sierra 1500!!! I am going to call them
Thanks for your help, hoping website just isnt updated to 2021?
I actually just finished a project to add several different lighting systems to the back of my truck. for mine I used a curt adapter for the 7 pin trailer harness and a putco harness intended for tail light bars. I cut up both harnesses and customized them for my exact application, using the curt harness to get 12V and ground and used the putco harness to trigger relays. the backup lights signal to the rear tail light activates a relay which connect power from the 7 pin harness to a set of LED light pods which I have integrated into the corner step pockets. This approach worked very well.
UPDATE:
As per Putco the 2021 is different as far as the trailer plug lighting up without a trailer plugged in. The 2021 needs to see the constant draw from the trailer.
The good news is this blade harness WILL work as needed!!!! Thanks Transient !Thanks Zelas !   BIG Help!!!!
I am having this same issue right now. I mounted two 7" led bars to the bottom of the bumper and wired them into the trailer harness like I did on my last 2 trucks (green with white strip for reverse power and solid white for neutral) but they wouldn't work. I tried putting the truck in trailer mode and still nothing because the trailer isn't actually connected.
Does anyone know which wires to tap into on the taillights are the power for the reverse? they seem to be pretty easy to tap into from under the truck without removing the lights and I do not want to buy a harness that cost more that the lights.
problem solved. I tied the power into the light green wire and neutral into the black wire coming off the harness from one of the rear tail lights. For everyone spending over $50 on a wiring harness, on top of whatever they paid for their lights... I spent $30 on 6" double row LED lights, plus electrical tape and some extra 18 guage wire. no need to break the bank on this project!
Happy it worked! I ordered the Putco plug in harness which will get me the trigger for the relay on backup lights. I dont know if it will have a constant 12V but can still tap the trailer plug as that has 12v only. I mounted the lights just awaiting harness. I did use a test light in the taillight harness and it seemed to be the light green wire as you said. My concern was it was very light gauge i assume due to the LED not needing much??
The Putco harness was more money than the LED light pods!! LOL
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
