IMG_7060.thumb.jpeg.fab9d7eed3b4f852fce009d80e242993.jpegThanks Guys! All good input! The Putco harness was a real quality piece. Had a wire for reverse which I used for my relay trigger. Only had to tap into the 12v constant on the trailer harness which is the only live wire on that harness in 2021 with no trailer hooked up. Came out great, this is what forums are for...help. Thanks guys!!!
Edited by seamus2154
Sorry Im a bit late but the reverse lights or all lighting in these trucks run through the BCM Body Control Module. Some higher power lights like the headlights have relays in the fuse boxes but those relays get their trigger from the BCM. I've added tons of LED lighting to my interior lights so when I open my door at night everything is lit, There is a limit to how much amperage the BCM can provide. It shouldn't damage anything but the BCM will trip out like a self resetting breaker it will try to start the load a few times and then give up until restarted (I found out when I wired too much to that specific output).
Also the light pods in the bumper step may mess with the blindspot microwave radar sensors (If equipped), i believe they are mounted behind the plastic bumper step in these T/1 trucks.
before I did the install I tested the cross traffic alert system with the light modules in place attached with painter's tape. I went to a parking lot and waited for traffic to drive by. all of the sensors worked properly. after the project was complete with everything installed in its final position I can confirm no effect on backup or cross traffic systems.
The sensors are indeed mounted to the inside surface of the step pockets, but towards the rear of the vehicle. To the rear of where the light pods are installed.
Edited by kodiakdenali
good to know.
My constant 12V is off the trailer plug to the relay. The trigger for reverse is from the Putco harness that is inline to taillights then to relay. Triggers and powers up reverse light perfectly, nothing times out or trips, and no issue with cross traffic or parking sensors. The extra light does not wash out the backup camera if anyone is concerned. It adjusts to the extra light. Might be under the threshold of the BCM but works perfectly.
  • 1 month later...
So I finally got to messing with my lights the other night after reading this and being disappointed the Curt RV harness I bought wouldn't work to tap the lights. I pulled the passenger tail light to see what the wires were for the bed lights and reverse lights. I built a harness from a 2 wire plug at my 2"x2" lights I mounted either side of the hitch. I used the black wire from the tail light harness for ground using T Taps. I tapped the blue wire for the cargo lights and the light green for reverse. I put diodes on both of those wires so I wouldn't get any back feed through the circuit since they combine to the positive wire of the LEDs. Now I have additional backup lights down low and can turn them on as cargo lights for hooking up a trailer or seeing behind at night if loading stuff up.
Looking good! Yep it was the light green wire for reverse. I used the Putco harness which was plug and play and had a reverse wire on plug. Made it a breeze. I was intitially taken back with the price till I received it. Very nice quality and didnt have to cut the wire.
What did you use to plug into the other side of the reverse light wire on the Putco harness? It looked like it had an OEM type weather seal connector but only the one side and not a pigtail to splice into the other side. I'm guessing it only works with the Putco blade light.
On 7/29/2021 at 9:13 AM, Zelas said:
This Is what you want to use. Its plug and play with reverse out.
https://www.putco.com/529005
This is definitely what you want to use. if you try to tap into the trailer wiring harness for 12v and grd, the ecu  thinks you have a trailer hooked up and puts you in trailer mode.
I put a marine panel in my bed to give me a 12v cigarette plug, dual usb port and switch to turn on the additional bed lighting and had to run a power line all the way to the battery to power it.
I was using that wire to trigger my relay, which then turned on my LED lights. So I cut the plug off and wired direct to the relay.
It didnt for me, I did find that the trailer harness was useless for any other light signals, I got all of those from a putco harness, but power and ground I got from the trailer harness without any side effects.
I am interested in your marine panel mod. I have plans for more bed mods, nothing built yet though. Do you have pictures of your setup? Could be inspirational.
I had to redo my harness and add a relay after I added the GM step lights and replaced the LED's from the kit with brighter ones I found on ebay. When the cargo lights were on it would cause the lights I added to flash and go off along with the lights in the bed. I used the far side of the tapped wires with the diode as inputs to trigger the relay from either the reverse lights or cargo lights. I tapped the Curt RV harness for the 12 volt + to power the lights. Now everything works as it should.
  • 3 months later...
Seems like a relay is a must when adding additional bed or perimeter lights. Good to know for future projects.
Throwing my write-up from another thread here to help others:
I added the GM light kit for my multi-flex tailgate as well as swapped the lights to brighter aftermarket LED units. I added some 2"x2" LED cubes I had purchased for my Avalanche but never used. The current draw tripped the BCM and they would blink 3 times then go off. I also hooked the cube lights up to the reverse signal so they come on in reverse and at night when the approach lights turn on when you unlock the truck or lock it and leave. I had added a Curt 5th wheel wiring harness expecting I could get my signals from there for what I was originally wanting to do. I found on here that only the 12V+ wire has signal at all times. I pulled the tail light and looked at the wiring. I have LED bed lights in the corners from factory. I tapped that wire on the passenger side(or could use drivers side) and ran that to the 86 wire on a waterproof relay. I added a diode to it so current can't back feed to the bed light circuit. I also tapped the reverse light on the same side, added another diode here so current can't back feed the circuit and added it to the 86 wire. There is a harness that plugs in under the bed and connects to the tail lights. I purchased a new harness to keep as a spare in case I ever had electrical issues that required me to take it to the dealer. I can unplug everything I added and return it to stock. 30 wire I connected to the 12V of the Curt 5th wheel harness I added. This plugs in via T to the factory trailer plug. I have the actual 7 wire plug running into the blank in the passenger bed side where the 120V outlet would be if I had that option. 85 wire can be tapped into the trailer harness ground wire or find a suitable ground wire elsewhere on the chassis or trail light harness. 87 connects to your additional lights. I didn't add a fuse to mine since I'm using the 12V+ from the trailer harness and it is already fused. 87a is NOT used and can be removed or taped off. I heat shrunk/electrical taped up connections and then zip tied the relay to the Curt 5th wheel harness along the tail panel of the bed.
For those not wanting to read it all:
Waterproof relay(as shown above)
30 wire - 12V+ from trailer wire circuit
85 wire - 12V- ground to trailer wire ground, taillight ground, or other suitable chassis ground
86 wire - 12V+ input from LED bed lights and/or reverse lights, using a diode on each input wire to prevent back feeding trigger circuit
87 wire - 12V+ to your additional lights
87a wire - NOT used and can be removed from relay harness or taped off. Not all relays have this pin/wire
  • 1 year later...
On 7/27/2021 at 9:04 PM, seamus2154 said:
Hey Guys! I have a New 2021 Sierra Denali 3.0 Duramax. Love it so far and have been sorting it out nicely. I have had 3 of the previous generation truck. I always mount LED rear backup lights on the rear bumper as some of the places I race have no lights in the parking lots. In the past I pull 12V power and the reverse light as a trigger wire for the relay for the lights, off the trailer wire connector. Well.......this 2021 does not light up that plug unless the trailer is connected. Once you plug in the truck recognizes a trailer is hooked up. For some reason there is 12V that is on but none of the other wires are live till a trailer is hooked up. I thought something was wrong so  hooked up the trailer and boom everything then works and the display states trailer hooked up.  So...I can get the 12v for the relay but now I am trying to find which wire on the rear tailight harness is the reverse lights? Appears to be the light green one I think?? But this truck is all LED and its a very light gauge wire. Does this truck have a LCM like the german cars.? Light control module. Will it sense a larger load and screw up something?? Pretty common with german cars. Also afraid to mess up any modules? I have wired 10 different pickups this way but the new generation is definetly different! Any advice for a trigger wire on relay?? Is that much of a load to the relay??
Thanks
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
