On 10/26/2022 at 1:13 PM, 64BAwagon said:
Not sure if its a 6mm but it takes a 10mm socket so it likely is.
Turns out it is a M8-1.25. A flange nut like on the rear of the heat shield would work great but I used a lock & flat washer and a nut combo as Home Depot was out of flange nuts.
Dipstick install thread:
Edited by Epsilon Plus
  • 5 months later...
Your blind. Not sure what that did for ya but there ya go.  If you go back probably first page or so on this thread I.believe the process to check the fluid it there. It's a similar process as my 11' BMW X5 and yes much more annoying, not a quick check after fuelling up or anything.
Edited by THE YETI
3 hours ago, JamesOneil said:
Noticed there is no trams dipstjick  Or am I just blind nearest suntrust bank  Please tell me I'm blind.
There is a sticky at the top of this section and even in this very thread on what you need to add a trans dipstick. It’s only three parts plus one nut and GM sells the parts. It’s not a hard install I just did mine a couple days ago.
  • 6 months later...
Looks like he is talking about the fill plug and not the level check plug. Hard to tell for sure what model that is but it likely has another plug in the bottom of the pan for level checks. Not to mention the fact that the truck needs to be at operating temp and running to do a level check.
You have to vet sources on TY, lots of people on there that dont know what they dont know, this guy is a good example.
    lanaderay
    lanaderay
  • Who's Online   6 Members, 0 Anonymous, 1,194 Guests (See full list)
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
