A Miss With Blis
My Blis system is malfunctioning , it will come on for no reason on the drivers side then go off for no reason. On the passenger side sometimes it works sometimes it doesn’t . Then it will work just fine . I only have 1500 miles on the truck. Has anyone else had any issues . I video tapped it  so I can show the service tech, because these things never malfunction when you take it in.
Properly is subject to interpretation. The only time I use adaptive cruise is on a 2 lane. Then it’s regular cruise. Every lane keep I’ve experienced wonders. Most of the time the aides are off. Especially if there are turn lanes.
If you're talking about the "Lane Keep Assist" or the "Lane Change Alert", mine was not working either. Last time in for service I had them check it, they did an update and now it works fine.
I Agree with above , mine was acting funky and service advisor said sometimes the system can get knocked off its geometry it should be in , but its an easy fix for them.  In and out within the hour.
