You can do whatever you want with enough drive, and the will to MAKE it happen!
You forgot the 2 other important things to make it happen...time and money
Yep, it was late when I wrote that. Forgot to start that off with, "With a big enough bank account, plenty of free time, ... "
Unless the drivetrain was free, sounds like a lot of work for 2 pretty old trucks.
If you don't have the whole wiring harness from the Dodge, think you are dead in the water before you even start.
First thing is emissions what are the requirements for the area. Tailpipe check it should pass no problem. Motor mounts, transmission mounts drive shaft mods, check. The wire harness is a must. It has to be a hemi otherwise why bother. Put a 6.0 in it. I’d do it. There are so many hemi engines out there it’s probably cheaper to go that route.
