Hey y'all. Just joining this forum. Seems like a great community!
My post title pretty much states the issue. It started in the past few months.
Symptoms: Mild rough idle, gets better with increased RPM - or maybe is just drowned out. Sometimes shows code O305.
Already done: change plugs, wires, coil pack.
Considering: pressure test, fuel injector replace, maybe isolated manifold leak? Of course, also dreaded collapsed lifter
Have read quite a few posts on this issue already, many point to AFM. However, wondering, does AFM affect cylinder 5? I didn't think so, unless something changed in 2014? Even if not, would you suspect collapsed lifter anyway? Any other thoughts?
The symptoms are mild at present, but I'd like to address sooner than later if that can help avoid (further?) engine damage.
Would appreciate any thoughts at all. This engine has high miles, but they are highway and I'd love to keep it going.
Cheers!
Only cylinder 1 and 7 are AFM on that side of the engine.
You could do a compression test to make sure that cylinder is even with the rest on that bank. Past that I'd be thinking injector issue.
Ran compression test on cylinders 3 and 5 and I'm getting exactly the same compression from each (~140 psi). It might be slightly higher, as I couldn't screw in the tester more than hand tight. While not high, that seems decent, right?
I'm just re-reading your post and realize I only ran on two cylinders and you suggest on the entire bank. I thought I would run on the two non AFM cylinders, but I suppose I should compare across the bank. I'll redo and report back.
Ok, just pulled all plugs on that bank and retested. I also watched a video on compression testing and learned that I need to turn the engine over about 4 times. I was just doing once before. This resulted in higher values:
Cylinder 1: 205
Cylinder 3: 195
Cylinder 5: 198
Cylinder 7: 190
Cylinder 7 is hard to reach so I couldn't tighten the tester as well, whereas cylinder 1 is easiest and I could tighten it properly. I think that could be a reason for the slightly lower values toward the back. That said, the values seem pretty good and consistent, right?
To recap what's been done so far: plugs, wires, coil pack on cylinder 5. Going to order a fuel injector next.
Edited by Ethan Erkel
Right, compression is not a problem here. It's fuel or spark right now and spark seems to be pretty well covered.
Well, changed all the spark plugs and... I'm still getting 0305 misfire in cylinder 5.
Bah!
I did find a P219A code. I think this happened once. Not sure if it's recent and I've now cleared the codes in trying to make sure I was in fact still getting a 0305 misfire, which, after waiting a while, showed up again.
What next? Any ideas would be much appreciated.
Ok, I did a hack vacuum leak test using a cigar. 😉 No smoke came out anywhere. It seems tight.
A few more details: This problem is most noticeable at idle. Acceleration is good and if I am running on the highway a lot (not stopping at lights, etc., meaning not idling, the light eventually will go away. This tells me that when above idle the misfire is happening much less (feel free to correct my thinking).
So I'm at a loss.
Could this be a sticky lifter/valve? Would this happen only at idle?
7 minutes ago, CrawlSlow said:
Is it tune by a shop? Or tune with one of those useless junk handheld? (I know it's junk because I have one). Go back to stock and your problem will be solved.
Sorry, I don't think I understood what you were asking. No special tune. This is all factory tune. Is that what you mean?
Another thing to check. Not sure if you have gas cap or not. When you open your gas cap, is there back pressure coming out. You can hear pressure being released.
Just tried. No sound of back pressure. Granted, the truck is almost empty at present. Should there be?
BTW, really appreciate your feedback!
Edited by Roger Rogers
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
