I know I'm probably one of the few folks that doesn't mind the feature on the new vehicles, and I know a lot of parameters are taken into consideration for it to operate. The only issue I am having is that when the engine does shut off at a red light, the engine only stays off for roughly 30 seconds, and most traffic lights are red for about 60 seconds, it would seem the fuel savings could be increased by staying off for the full duration of the light. Has anyone found a way to extend the "off time"? So far I have operated the truck in ambient temps between 60 to 90 degrees and tried turning off the hvac and other accessories, still haven't been able to extend the off time.
Its controlled by the ecm and there is no way to change the parameters;  Have to live with the way it is.  PS, I turn off every start.
  • Thanks 1
Say what?! My 2019 has never turned back on by itself. I have to lift the break or tap the gas. I too turn it off every time I start.  Have I really had this truck that long and not sat with it off long enough for this even to happen?
Edited by Minnvmax
My experience has been that if I turn the A/C off, the engine stays off until I take my foot off of the brake. That's true for as long as the red light lasts. I'm sure if I were to sit there too long, the engine would kick back on.
...but if my A/C is on, it kicks back on in 30 seconds or so.
Edited by bdallas
add info
Time limit for the stop portion of auto stop/start is 2 minutes.
If it's starting sooner it's one of the other reasons.
Autostart Criteria
Driver Enabled Conditions that will engage Autostart:
• Driver removes pressure from the brake or depresses the accelerator pedal while the vehicle is in the forward Drive gear System Enabled Conditions that will engage Autostart
Note: If one or more of the following conditions occur, the system will force the engine to restart.
• Economy mode turned OFF
• Brake booster vacuum is less than 40 kPa (6 PSI)
• HVAC inside air temperature changes than 3°C (5°F) (with HVAC Automatic)
• A/C compressor request from HVAC (A/C or Defrost modes)
• Battery voltage less than 11 V,
• Battery state of charge is less than 73% (changes with state of health)
• Driver door status changes to open and driver seat belt status changes to unbuckled (not applicable to vehicles in North America)
• Hood switch status changes to open
• Autostop time exceeded 2 min
If the crank time exceeds 2 s, a manual ignition switch restart will be necessary.
I believe 'Economy mode' refers to one of the modes for the charging system
Autostart Criteria
Thanks for the posting, out of all the stuff I read on the topic yours is the first I have seen that mentions the 2 minute max, maybe mine being the 2.7 has different requirements for the start stop. Perhaps I just haven't hit the just right conditions for the engine to stay off for more than 30 seconds. Also I do want to add that I too shut off the feature when I know I'm in an area where there is a lot of stop signs or when I'm maneuvering around where auto stop make no sense or is a nuisance.
My wife's 21 Acadia Denali does not have any option to turn it off. Most of the time it doesn't bother me as I don't drive in a lot of traffic with lights due to where we live. If it shuts off at a stoplight, it turns on quick enough not to be an inconvenience. It does turn back on after a certain time. Definitely using the AC keeps the engine on more.
The worst situation I endure is a 4-way stop where I have to wait for someone else to clear the intersection, I may be sitting still for 2 seconds but the engine shuts off in that time, then re-starts. Its teaching me to roll through the stop sign rather than hard-stop it.
They will only do one stop/start cycle per stop.
Lift foot off brake just enough to get a restart and it will stay running for however long to continue to be stopped.
Our 2020 Acadia Denali has the stop/start disable switch on the console just ahead of the cup holders.
2021 Acadia OM -- Auto Stop Disable Switch  Graphic
Well holy &^%$, there it is. I just went out and looked. We do have it. I swore I read somewhere that it didn't exist and I never bothered to look.
I'm pretty used to it shutting off now, and yes, just lifting the foot 90% off the brake it will fire up. Now I don't know what I'll do when driving her vehicle around. My truck is a 15 so I don't have to worry about it at all.
Well, Did some test running late yesterday. Engine and tranny up to operating temps, hvac set and maintaining the same outside temp, longest the engine would stay off was about 40 seconds.
Turned the hvac completely off and the engine would stay off for 2 minutes. All normal I guess. Thanks for helping me through it.
Keeping your foot firmly on the brakes makes a difference. If you lighten it, the truck thinks you're just slowing down in traffic. I also think having accessories being charged shortens the off time.
That one I figured out one the first day.
My last car had "auto hold", one feature I kinda miss. Come to a complete stop and you could take your foot off the brake and it stayed put til you hit the gas.
I got sick of hitting the button every time.  Bought the auto stop start eliminator from 4Dtech.  Works perfect every time.  Took about 30 min to install.  They have an excellent step by step video on how to install it.  After driving around with it for 2 months I found no change in my mileage. It just eliminates the annoying restart after every stop.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 722 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
