Hey guys I’m looking for a way or suggestions to cover all the chrome on my Silverado. Between the bumpers, the pice where the bow tie is and the mirror caps there is just too much! I was looking at some plastic covers, possibly replacing the bumpers or having them vinyl wrapped. Does anyone have any advice or suggestions?
  • Haha 2
Enjoy it!  How about having it blasted off and the pieces powder coated black or painted to match?
Have them wrapped, get them painted, find painted used ones, take your pick
you can buy black mirror caps from GM
Your pic is crooked btw
Edited by Dirk13
  • Haha 1
The grill comes off pretty easy and the center chrome detaches. I took mine apart, planning to spray w/ removable coating, but ended up sanding and spraying with a black chrome paint. Looks good, but should have prepped better, it has chipped some. The gold bowtie also separates from grill, making painting it very easy.
I've done some pieces in vinyl wrap. That works well too. Buying nicer wrap is well worth the money, it is more workable and forgiving. Vinyl wrapping is an art to get it right, imo. Im still learning.
Got some pics of the black chrome? I'd like to see that.
Headlights also have a slight tint applied.
I was going to blackout the lower chrome area, but will likely be doing a hidden winch bumper which replaces that piece.
Look's good so far. Why not a blue bowtie ??
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
