So, I found a sweet set of rims at 20"×10.0, too sexy to pass on.. and the closest tire I can find for my all terrain preference is 275/60/R20. I've seen people use that configuration on Ram. Has anyone seen it on chev? Or anyone currently running it? I would love to see a picture or something.. or anything else you can advise.. looking for a budget upgrade. And thid ended up being the perfect set up to my appealing eye. Just hope it will work. Any thoughts?
Your best bet for a truly good answer would be the correct forum section on this site:
2014 - 2019 Silverado & Sierra - GM-Trucks.com
This is the T1 new body 2019+up section, so some of the answers you might get here aren't 100% for your truck which is a 2019 LD old body per your trailer brake thread.
That said, 275/60R20 should fit without a level on a factory wheel.  It might slightly rub in a spot or two.  On an aftermarket wheel, I can't say for sure as offset and wheel width will have a lot of play involved in that.
I would check the 2014-2019 section for any wheel and tire fitment threads and see if anything there stands out.
Being an LD, your available wheel options are different than the T1's due to different offsets/backspacing, fender clearances, and suspension clearances.  What works on an LD will not necessarily work on a T1 so you would be limiting yourself by asking T1 owners "What Fits?".   I would try the other forum for best results.
https://www.customwheeloffset.com/wheel-offset-gallery
check out their searchable gallery for different wheel sizes, etc.
275/60R20 is a current GM pickup factory size.
Current 20's in use:
QAB   Tires, 275/60R20 all-season, blackwall
1 - Standard and only available on 2WD models.
--    S    --    A    A    A    --    whitebox.gif    whitebox.gif1
QAE   Tires, 275/60R20SL all-terrain, blackwall
1 - Requires (RD5) 20" wheels. Includes (QAQ) spare tire.
2 - Includes (QAQ) spare tire.
3 - Standard on 4WD models. Available as a free flow option on 2WD models.
--    A    A1 A2 A    A2 A1 A2 whitebox.gif3
QFV   Tires, LT265/60R20 blackwall Goodyear Wrangler Territory MT
--    --    A1 --    --    --    A1 --    --
Edited by redwngr
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 1 Anonymous, 4,143 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
