So for some reason my 2011 gmc sierra lately has been going into v4 at random times just for a few seconds then back to a v8. I took it the the GMC dealership and they told me nothing was wrong with the AFM but it still is doing it very randomly and when it goes back from 4v into v8 it takes a second and jerks a little bit. should I just get a AFM disabler or what im so lost on what is wrong.
Obviously its your truck, and your choice.  I think the general consensus amongst early AFM trucks is to disable it, I think mainly to prevent the lifter tick issue.  I honestly dont know why anyone would want this feature in a full size truck anyway.
From what I have read most folks disable the AFM before it destroys the engine. I think there is a way to turn it off with the right scanner.
That's normal operation.  It's not really random, certain parameters are met allowing it to turn on and then off.
If you feel it, it's probably time for a new driver's side engine mount.  Dirty old oil is AFMs worst enemy, keep it clean and fresh and the system is quite reliable.
also when driving it today it seem to get stuck in v4 and take a second to get back into v8 i do have a small cut in the exhuast could that effect it?
The above? That is rock solid advice.
Don't trouble trouble until trouble troubles you.
1 hour ago, Reed_2021 said:
just curious what would the divers side engine mount do?
Allow you to feel more engine vibrations such as when AFM kicks in and out.  The mounts are fluid filled and last about 8 years or so.
Do you mean the motor was cruising along in V4 and then you stepped on it and it took more than a second to light off the other four cylinders?  If yours were mine, I would put my Tech-2 on it and see what's going on with the AFM VLOM solenoids.
When these fail or slow down and get out of time, they take out the lifters which can lead to bigger problems.  Anytime repairs are made in this area, it is SOP to replace the VLOM and all of the lifter trays.
Happen to be in Florida?
Yeah it takes a little to set off the other 4 so I should check the code and see if anything pops up? I can look at the code at o Riley’s right?
There's no code or CEL that comes on when this happens...you have to have a Tech2 scanner to read the status of everything "live"
I took it to the dealership to get checked but they said their is nothing wrong with my AFM but yet my truck still takes a second to go from v4 back into v8. could it be the VLOM filter or even the lifters themselves?
What it could be is you feeling the converter clutch unlock at the point of switching which it is suppose to do.
9 hours ago, Reed_2021 said:
maybe but it just started doing it
Here's a thought. Without a Tech-2 you have  no idea 'when' the switch signal is being generated. Meaning the comment, "Over a second" to switch is without reference to anything but your expectations.
They did actually looked at it and didn't find anything wrong with the AFM.
I'd believe them.
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
    • Just pull the inside door handle.  It has mechanical override to the lock.
    • Got to have those sliding doors. One of my favorite things about a minivan. The Kia does a good job of making a minivan look like an SUV. I may do a Toyota next. I want the awd option.
    • I took my 24 Sierra Denali 4wd in at 37,000 miles. Had the mileage maintenance checks done, asked them to change out the two limited slip differentials, including the limited slip additive, and change out the transfer case fluid. They rotated my tires, verified my shocks weren’t leaking, and whatever minor checkouts that were on the list for 37,000 miles. About three hours later, they charged me $600 and sent me off. I was considering having the 10-speed transmission serviced, but between the posts on this forum and previous experiences with transmission failures after a fluid and filter change, I decided against the tranny fluid changeout when the service advisor told me it would take about 3 hours and cost about $500. After growing up working in three different full-service gas stations, I know to stay far away from flushing machines connected to any automatic transmission. I don’t meet the severe duty schedule, but I may follow the 45,000 mile tranny service, unless  i see more problems from doing so on the forums. I expect I will want to watch the entire procedure. The various utube videos do a decent job of showing how much time and attention should be taken for a correct fluid &filter replacement, so witnessing the procedure seems something I should do. Trust but Verify🥳 Otherwise, I’ll follow the owner’s manual recommendations, whatever they are.
