So for some reason my 2011 gmc sierra lately has been going into v4 at random times just for a few seconds then back to a v8. I took it the the GMC dealership and they told me nothing was wrong with the AFM but it still is doing it very randomly and when it goes back from 4v into v8 it takes a second and jerks a little bit. should I just get a AFM disabler or what im so lost on what is wrong.
Obviously its your truck, and your choice.  I think the general consensus amongst early AFM trucks is to disable it, I think mainly to prevent the lifter tick issue.  I honestly dont know why anyone would want this feature in a full size truck anyway.
From what I have read most folks disable the AFM before it destroys the engine. I think there is a way to turn it off with the right scanner.
That's normal operation.  It's not really random, certain parameters are met allowing it to turn on and then off.
If you feel it, it's probably time for a new driver's side engine mount.  Dirty old oil is AFMs worst enemy, keep it clean and fresh and the system is quite reliable.
also when driving it today it seem to get stuck in v4 and take a second to get back into v8 i do have a small cut in the exhuast could that effect it?
The above? That is rock solid advice.
Don't trouble trouble until trouble troubles you.
1 hour ago, Reed_2021 said:
just curious what would the divers side engine mount do?
Allow you to feel more engine vibrations such as when AFM kicks in and out.  The mounts are fluid filled and last about 8 years or so.
Do you mean the motor was cruising along in V4 and then you stepped on it and it took more than a second to light off the other four cylinders?  If yours were mine, I would put my Tech-2 on it and see what's going on with the AFM VLOM solenoids.
When these fail or slow down and get out of time, they take out the lifters which can lead to bigger problems.  Anytime repairs are made in this area, it is SOP to replace the VLOM and all of the lifter trays.
Happen to be in Florida?
Yeah it takes a little to set off the other 4 so I should check the code and see if anything pops up? I can look at the code at o Riley’s right?
There's no code or CEL that comes on when this happens...you have to have a Tech2 scanner to read the status of everything "live"
I took it to the dealership to get checked but they said their is nothing wrong with my AFM but yet my truck still takes a second to go from v4 back into v8. could it be the VLOM filter or even the lifters themselves?
What it could be is you feeling the converter clutch unlock at the point of switching which it is suppose to do.
9 hours ago, Reed_2021 said:
maybe but it just started doing it
Here's a thought. Without a Tech-2 you have  no idea 'when' the switch signal is being generated. Meaning the comment, "Over a second" to switch is without reference to anything but your expectations.
They did actually looked at it and didn't find anything wrong with the AFM.
I'd believe them.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
