So we all know these topics are beaten to death, but I wanted to see if there's anyone on here running this tire size on stock suspension. I put on 275 65 r18 falken wildpeak at3w which should fit without question. The 22" wheel option on the silverado works out to roughly this size. Falken says the at3w measures 32.1 x 10.9 on an 8" rim. My rim is 8.5", which shouldn't really affect it?
Rub's in reverse, even before full lock and I can't tell where its rubbing. Not seeing any indication on the wheel well or the tire and when I rotate the tire's in park it doesn't seem to hit anywhere. The only place it comes slightly close to is one of the bolts holding the mudflaps up. But I don't think the bolt is causing it, the location of it doesnt really align with how far I think the wheel is rotated...
  • Confused 1
I agree, not sure why you're getting a rub somewhere.
That size tire isn't much different than what came stock on my truck.
Edited by MikeBMW
I mispelled a word, sorry.
It look like for every half inch increase in rim width the tire width will increase 2/10", which puts it at 11.1". Not enough to worry about though.
I didn't want to level it, but it looks like I'll have to see if I can find a 1/2" spacer or something.
Turns out it's the backspacing. 22" wheel option has about an extra 1/4 inch.
Oem 20" wheels do even better upsizing tires with even greater back spacing.
Tires hit the upper control arms and a bolt on the mud flap. I can probably swap the bolt out for something with a lower profile. It's just mounted to the cloth wheel well anyways.
I hoping someone that is knowledgeable in wheel spacers and leveling kits can help me out. I don't know exactly what I need or what I should be looking for so the tire clears. I've looked into wheel spacers that are 1/2, 7/8, 1 1/2. Obviously backspacing increases but I don't know if that will just lead to clearance issues somewhere else.
I've also considered trying to find a small leveling kit, for ex. Install the lower shock spacer from a kit and leave the top out (can you do this?) But I don't know if a leveling kit small or full height would solve my clearance issues because of the back spacing.
Any help is greatly appreciated. I went into this thinking I'd just put a slightly larger tire on..
Edited by M1ck3y
A spacer may keep you from rubbing the UCA but it will, also, cause more rub on your fenders without a level or a lift.
Think about drawing a straight line as your tire turns, as you push it out, it will contact more of your fender since you pushed it in that direction and is no longer tucked within the wheel well.
Before I installed the 35s, I measured on the 33s and determined, with the same wheel (Factory 18x8.5 Wheel Offset = +24 mm - Back Space = 5.70" Inches) I needed to trim a bit on the inside liner at the rear.
Your stock 20s are Factory 20x9.0 Wheel Offset = +27 mm - Back Space = 6.06" Inches.
The back space is your issue. If you already are getting an issue with rubbing on the fender a spacer will make it worse.
A level might cause worse rubbing on the control arm unless you put in a spacer, and the level might help with fender rubbing issues caused by the spacer.
A 1/4" spacer, max, with a 2" level and you should be good.
Fun stuff, eh? :D
EDIT: there are many bottom spacers tor the struts for a 2" level - I started with an RC lower spacer for a 2" level and easily fit 33x12.5x18s.
https://www.roughcountry.com/gm-leveling-lift-kit-1307.html
Edited by MikeBMW
  • Thanks 1
Fun stuff, eh? :D
Thanks Mike!
Maybe I'll see if I can get away with doing a 1" or 1.5" spacer and see if that gives me enough clearance. I'm just concerned if I go full height the tires are going to look to small.
If that doesn't work out I'm thinking I'll end up looking at buying new wheels. I think wheel with around 0 offset with 5" backspacing should give me enough room?
A 1" or 1.5" spacer is not a good choice, IMO - I hate spacers (maybe a 1/4" or 1/2" is OK), best to have the offset in the wheel itself.
Now you're talking. Still, a 2" level, at minimum, will be required.
Edited by MikeBMW
I should have said 1.5" strut spacer. I see procomp has a kit that says it clears 32's. Waiting to hear back if they think it's right for my application.
I looked hard at going with a wheel spacer. But in the end I decided that at times I drive way too aggressive to be putting on part that... really shouldn't be there.
Ah, gotcha! I'd still recommend a 2" level, minimum.
If you go above that, you'll also need to get aftermarket UCAs.
I agree! :D
I have 2 inch spacers front. Waiting it’s in the mail for a 3 inch block lift rear. I have the new 3 inch shocks also. Plus I have a 1.5 inch zone body lift sitting in the truck. Gunna pay for install. But I also have new rims and tires with new tpms waiting to go on. 305 70 17 -38 mm offset
You do mean "strut spacers," correct?
And not wheel spacers?
To me, spacers are a wheel item, strut spacers (or a level) are a strut item.
Edited by MikeBMW
Yes sir a level. Strut level. I got rim offset don’t believe in wheel spacers.
Did you guys find wheels that matched the oe hub bore size, or are you running hub centric rings? Little confused about this because everything I've read says you want the hub/bore to transfer load to the wheel. But it looks like the majority of aftermarket wheels don't match, and its just a friction fit? Does that make them lug centric?
I went with Fuel Tech D670. Its a 18x9 +1 offset 5.04" Backspacing. I'm hoping that since its only a 32" tire it should clear 🤞
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
