I have a 2004 SLT 4x4 with bad brakes. I had the brake lines replaced 4 years ago when they rusted out and started leaking.
Brakes now go all the way to the floor and stop the truck although slowly. Just paid $700 for new front calipers, rotors, pads and lines. Bled with scan tool. This did not improve the brakes. Mechanic said the auxiliary P/B booster pump is bad. When plugged into the harness it runs continually with vacuum and pressure at the nipples. This part is unavailable. Part #
89058946. Do I now junk the truck due to an part that is not obtainable?
Has anyone else had experience in solving this problem? Is there a solution?
Thanks for the links. I just talked to GMC shop. They advised to bring the truck in. Their thinking it is not a problem with the booster pump as it runs and creates vacuum. They are thinking that I may still need  lines bled manually first at rear wheels then front then at the abs block. Also to check master cylinder. I guess I will try this before trading it in for a ugh Mopar.
booster will not cause your problem, most likely bad master cylinder. a bad booster would cause the pedal to be hard to depress enough to stop the truck but not affect pedal travel
Thanks. Getting that checked at GMC shop next week. I can hold the brake all the way down give it a little throttle and the truck will start moving with the brakes pushed! Looks as though I may have spent $$$ on new calipers, rotors, pads, and brake hoses that weren't needed. Live and maybe learn.
Yeah the calipers, pads and such aren't your problem; a master cylinder issue is my educated guess. GM publishes trouble shooting checklists for all systems....
Edited by dna9656
Thanks. So to the dealership next week to spend more money all on a truck that is to be traded in. just didn't like the idea of passing the truck off with a known safety issue even if the dealer will probably send it to auction.
can you pump the pedal and have it come up and stay there with your foot on it?if so theres still air in the system somewhere. if it still creeps to the floor its either the master cylinder or you have a leak somewhere
OK. So most likely the master cylinder. It will not stay pumped up and their are no discernible leaks. I now remember that not long after I got the truck I did have a brake fluid leak and all the brake lines were replaced. This was about 4 years ago. The mechanic said there was one item he was not able to replace because it was too rusted. The brake line kit parts were supplied by GMC at their cost. It was after this happened that all the trouble started. I questioned that tech about the weak spongy brakes after the repair and he said that is just the way they are with abs. Recently had a cam and dyno tune installed. The tune increased my idle speed slightly and now it seems really hesitant to stop and to hold at a stop.  I guess I could have the most recent repair shop that replaced the calipers, rotors, pads and hoses to do a master cylinder as he has wasted $800 of my $ maybe he will give me a break! That or just go on to the dealership?
lots of shops just looking to make the fast easy $doing half ass brake jobs, the mark up on brake parts here north of Boston is %100. they didnt take the time to properly diagnose your problem OR when they did the job they pushed crap back into the abs & master. the properway to compress calipers is 2 clamp off the brake hoses and open the bleeders as the calipers are the lowest parts in the system so all the debris ends up  in them. VERY few techs do this tho. its a shame you have to go to the dealer and cant find a competant independant.. the shop that did the brake job was foolish to release the truck like it is, you could easily have crashed and hurt yourself or someone else opening them up to a lawsuit. its 1 thing if your truck doesnt start but a whole different thing if it doesnt stop
This is the same shop that removed the aux. booster motor, said it was faulty and hooked the brakes back up with the vac line into the booster instead of through the aux booster motor. I had to ask for the aux motor back. When I plug in the motor it runs and pulls vacuum. Now I need to remount it along with bleeding or master cylinder.
Is this correct operation for this part??
  • 2 years later...
    • Done. I'll have more productive conversations with a hickory stump. Carry on! Keep the blindfolds on TIGHT!
    • This again?   https://www.reuters.com/fact-check/us-capitol-attack-rioters-had-weapons-including-firearms-2025-01-16/   Think Reuters is biased?  Check their rating https://mediabiasfactcheck.com/reuters/
    • I found an odor eliminator spray that neutralizes unwanted smells pretty well. Using it with the car's AC running helps to distribute it evenly around the cabin.
    • WTI futures / speculation is just that. WTI futures <> current 4-7% inflation and national average gas price over $4.00/gallon.   The spot price, at delivery, is currently $87-$95/barrel which is why gas prices remain high.   Edit: oH mY gOd mEnTaL BrEaKdoWn In tHE pOsT aBOve mInE. TrUmpErS goNnA tRumP
    • He does, actually. In another unrelated video he mentions the president called him in the middle of the night to relay some information on a cause (religious based) that he's invested in. Glenn expressed concern that another leftist administration could wield too much power with some procedure the Pentagon was using, classifying certain religions a certain way. Being that he is LDS (Latter Day Saints), he gets hate all the time from ALL over the political spectrum, so he's invested in this. Trump called him back at 5AM to tell him he had made some changes to that classification.   So, yes, they are and have been in contact regularly since the start of the administration. Glenn, of course, always asks his permission before discussing anything on the air.   I already spent an hour or more just searching for these videos. I may have my numbers wrong - I'm not a numbers guy. It may have been a MILLION barrels, not 1.5. The point is, our President, by his actions, gives a crap about America, and US - this is completely OPPOSITE the actions of the prior administration who projected hatred for anyone who wasn't following the left's edicts in lock-step.   Remember, they called January 6th an "Insurrection", when there were ZERO weapons among the crowd, undercover FBI agents agitating the crowd, along with paid leftists acting as aggressors, egging the crowd on in an attempt to whip everyone into a frenzy. It's all been proven.  Pelosi refused Trumps request for more National Guard troops. This smells 100% like an inside job for those with critical thinking skills. Only a handful of guys in the crowd got wrapped up in that, thankfully, but EVERYONE was searched out based on cell phone data, and charges were brought against many. And 6 or so people were locked up and left in solitary confinement for YEARS with ZERO due process!! If you give the slightest crap about our Nation, REGARDLESS of your political leanings, this should frighten you to your core. This is what men suffered, bled, fought, and died against 250 years ago!   This has gone FAR BEYOND left vs. right. This is a  threat to America, and our way of life. This is PRECISELY why Trump, a BILLIONAIRE who could have chosen to take Melania and sit on some tropical island that he could afford to buy himself and RELAX, instead chose to run for office, get hate from literally every corner of the media, get ATTEMPTS on his LIFE constantly, and begin to repair some of the severe damage that's been done to this Great Nation.   I don't know why I bother wasting my precious time here. Everyone has their minds made up. They won't realize we all were correct until it's too late ... after they elect another tyrant that hates America to office (Obama), or another puppet whose administration is secretly running the show behind the scenes (Biden).
