Had my oil changed at the nearest dealer about 500 miles ago, maybe 2 weeks ago on my 2020 duramax.  The second oil change, and the truck only has a little over 10,500 miles on it.  I checked my oil today and it is black!  Level is full, but it is black and looks old.  Won't be able to get the truck to the dealer until next week.
Am I wrong in thinking the oil could not be the way, unless they didn't actually change it?  I did not check the oil at the dealership before I pulled off the lot, but will from here on.
Happens to ALL diesel motors. Combustion soot colors the oil. It's fine. First time you noticed this in 10K miles? Yikes! Check you level more often.
  • Like 3
Oil Myth: The color of the oil indicates when it’s time for an oil change
It’s common to assume that black motor oil has worn out or become too saturated with contaminants to protect your engine and requires changing. Not necessarily.
The only surefire way to determine if the oil has reached the end of its service life is to perform oil analysis. Chemically analyzing an oil sample reveals the condition of the oil, the presence of contaminants, fuel dilution and so on.
Absent oil analysis, it’s best to follow the oil-change recommendation given in your vehicle owner’s manual or by the motor oil manufacturer.
It’s best to trust the data, not your eye, in this case. Otherwise, changing the oil could amount to throwing away good oil.
  • Heat cycles naturally darken motor oil
  • Soot causes oil to turn black
Black oil is what happens to diesels.  My 2014 Cruze diesel is black pretty much after I change it and drive it off the ramps.  Not really pitch black but after a few miles it gets to be the normal diesel black oil.
  • Like 3
I have checked it at intervals, after the first oil change, around 400 miles after that change it was not black like this.  I am talking about pitch black.  A thousand or more miles after a change, yeah I see it being black, and would not think anything about it.
While heat cycles cause oil to darken, soot causes oil to turn black. Most people associate soot with diesel engines, but gasoline engines can produce soot as well, particularly modern gasoline-direct-injection engines.
Soot is a byproduct of incomplete combustion. Since soot particles are less than one micron in size, they typically don’t cause engine wear. For comparison, a human hair is roughly 70 microns in diameter.
If soot particles agglomerate into larger wear-causing contaminants, the oil filter will catch them. Sometimes people who use bypass filtration systems, which can filter contaminants down to two microns, express surprise that the motor oil is still black. Soot, however, can still elude filtration down to two microns. Any finer filtration and the filter could catch dissolved additives in the motor oil.
Then it is dong better than many. Be happy...don't worrry.
  • Like 3
Haha, Ya, you should check your oil more often. I check it every time I fill the fuel, on every rig I own.
Hopefully they get a 'cold' check once in a while too.
I thought by now most vehicles had a trigger check oil light when they reach a qt low or 2.
Normal of all diesels.
Agreed. The longer the oil sits, the more accurate the reading. I wonder if there is any measurable increase in oil volume with temperature changes, for instance the way that transmission fluid expands when hot.
Yes. New motor oil has a 'average' volumetric thermal expansion of .000389 per *F. Or .0007 per *C.
POA's expand about 5-7% less than mineral based oils. That is of the expansion volume.
A system I am currently working has a 5 quart capacity. Checked cold, no 32 F vs a hot check of say 160-162 F is a difference of 8 ounces. On a warm summer day of say 80 F that would be about 5 ounces. A PAO would be about 5-7% less...roughly a quarter to a third of an ounce.
On a dipstick that is a quart between full and hot about 25% of it's range on a cold day in this example.
There's a calculator for that: https://www.engineeringtoolbox.com/volumetric-temperature-expansion-d_315.html
Just use the right units and fluid expansion rates.
Also means I've been overcharging my wife's Terrain. :banghead:
Thanks for making me look into this.....
Edited by Grumpy Bear
    d.lowrey
    d.lowrey
  • Who's Online   2 Members, 0 Anonymous, 1,979 Guests (See full list)
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
    • Fix one problem and find another.   Truck didn't have a thermostat in it so I flushed out the system today and refilled with 50/50 Dexcool. This truck is so old (LOL) that it has a sticker under the hood alerting people to the fact that it contains such. There is also an orange supplement with the owner's manual alerting the owner that "Your vehicle is one of a number of late production 1995 General Motors vehicles that use a newly developed engine coolant in the cooling system..."   I was still a little flummoxed by what seemed like a rich condition (exhaust smell, and a puff of carbon with a punchy rev). While watching the coolant temperature and testing the thermostat with my scanner, I happened to notice the IAT (incoming air temperature) to the intake was -40F. I know the temp is below average today, but I can still feel my face, and I was wearing shorts.   D'oh!! I realized I had never plugged the IAT back in, and the airbox was out while I was doing coolant. So I paused, reinstalled the airbox and plugged in the IAT, and viola. Things cleared right up, and I watched the coolant temp climb to a reported 198 degrees on the scanner (195 thermostat) and then it dropped to 194 (open) and then back up to 198 and held. Let it cool, came back, checked the coolant level and was satisifed.   Victory lap?   It needed more than the couple of gallons of gas I put in it from almost bone dry, so I ran it up to the gas station. It had earned it, or, at least I was pretty certain I wouldn't be draining or removing the tank anytime soon.   CEL popped on just as I was cruising a nice steady 40mph, just after coasting down a slight downhill curve.. Of course, it did, because, why let me enjoy not having dash emojis for a little while.   I just happened to have the scanner plugged in. I don't text and drive but I might scan and drive. Don't tell the police.   P0401, EGR flow insufficient.    Well, hello, EGR... ...my old friend! Welcome to the party, now that the engine reaches the factory-programmed operating temperature. I'm sure it was gagging on hostile, rich exhaust and carbon this whole time so I'll take it off and look again.   At least it's easily accessible, and worst case, about $65 to replace.   To keep, or to sell... Hmm. I want it running correctly either way. It's easier to sell when there are no fault codes.   It needs tires (they're aged out and cracking)   It could probably use an oil pan seal, or maybe the timing cover gasket/ junction with the pan needs redone because I've got an issue there that leaves a drop of oil on the floor.   If I do tires I'm sure they'll say the ball joints could use freshening, and, and, and, and.... At some point I'll have to stop. I can't (shouldn't) make it perfect, that's not what this rig is.
