I just purchased a 2020 Silverado 1500 LT that was part of the Hertz rental fleet.  Love the truck but would like to upgrade a few items.  One item in particular is to upfit the manual temperature control on the center console to the electronic control unit from an LTZ.  Is it doable as a plug and play or not?
Thanks in advance,
Bob
With enough time and money anything is possible.  The real question is, Are your pockets deep enough?
I'm not an expert, but iirc, there are going to be a few hiccups.  Controls being different might mean your radio screen is different.  Not having auto climate control from the factory means you don't have the sensors throughout the cab for auto climate control.  While the radio screen issue might be possible to resolve aftermarket, I don't think the lack of temp sensors can be.  I foresee an electrical nightmare.  I'm no expert.  Hopefully somebody else comes in that has more knowledge than I.
Edited by Transient
Thanks in advance,
Bob
Would it be possible to attach a picture? Never seen manual controls.
I agree with Transient, unless you have access to a parts truck that has the system you desire and the time and knowledge to install every thing . its not going to be a plug and play I don't believe but maybe some 1 else has more knowledge than us
you may run into body control module issues as well, I would leave the can of worms closed
Not going to work. The whole HVAC unit is different for the dual zone and electronic controls. The BCM's are vehicle specific and can't be reused on another vehicle. The only reasonable option is to trade it for one with the equipment you really want. Otherwise you're going to create a hack job nightmare that no one will want to buy if you ever decide to sell it and the options don't match how it was built.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 512 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
