Are these 305's or 315's?
i think they are 285's as well.... 305's at the largest... no way are they 315's... you'd need a lift for those and that looks like a stock 2500HD
Lol ... just to keep things even, I'll say 305's! :uhoh:
Actually, a buddy at work just got a set of 285's on an identical truck and, while the height looks about the same, his don't look as wide as the ones on the truck in the pic. And that should be about right since the 285's are a bit taller but not as wide as the 305's.
$.02
Remember 305 refers to section width, not tread width and the height comes into play with the aspect ratio.
1 inch=approx 25.4 mm
So a 305 would be 12 inches from sidewall to sidewall, then with an aspect ratio of 75 on a 15 inch rim, you get a height of about 33".
Well, the 305's that I've seen (for instance, Goodyear's MTRs) have an aspect ratio of 70 ... which makes em just a tad smaller (in diameter) than the 285/75's. However, if the aspect ratio is 75, then you're definitely correct ... they'd be taller.
ChevyHDGert, if ya find out what size they are, let us know! :uhoh:
Close but no banana folks
305/70/16 is a 33 inch tire x 12 wide
285/75/16 is also a 33 inch tire x 12.5 wide
Yes these are approximate. Different manufacturers differ a bit.
:cheers::cool::smash:
The first number (305 and 285 respectively in this case) is the section width (in millimeters. And since 285<305 ... it can't be wider. Given 25.4 mm in an inch
285 mm = ~11.2"
305 mm = ~12.0"
The second number is a percentage and is used to calculate section height (distance from the bead to the outside of the tread). Once you have section height, double it (once for the top of the tire and once for the bottom), add the wheel diameter and you have the overall diameter of the tire. So in this case that would be 32.8" for the 305 and the same on the 285. So I was wrong in saying the 305 was shorter. I'd never done the calculation myself until now, I based that on a tire size chart for Wrangler MTRs or some other tire I looked at in the past. Sorry for the misinformation. But the 305 is definitely wider! :rolleyes:
PS - I just did the "Ask Seller a Question" thing on ebay so hopefully he'll tell me what size tires those are ... I'm all curious now! hehe.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
