I still do my own oil changes. That kid may do more than Ill do in a lifetime but if they are all done shabby....my few becomes better than his 1000.
Yea they definitely want an incompetent boob doing oil changes. Making sure you don’t come back for repairs. Makes sense to me.
You say it like that doesn't happen. It does not matter in the least what profession it is in, there is incompetence. The lettering on my tailgate has now been done three times due to it. The same guy gouged part of the plastic trim trying to fix my seat cover. That same guy also couldn't put the foam back on correctly. We have all heard horror stories about mechanics who seemingly forgot to put the oil back. Don't get me wrong, I am not saying it happens 10% of the time or any great number but it does indeed happen. It doesn't really suck til its you that has to be that one.
I’m not saying there’re all perfect. I’m my 66 years I’ve seen incompetence. Not everyone suited for the job. Have you noticed the last year in a half. It happens even in the most important occupation. I use to do all my work when I bought used vehicles they were usually beaters when I was younger first married. As I bought newer vehicles with warranty I used them for service. It’s easy to determine who’s at fault. Ifs there’s a problem. If they do all the work. I watch they know it, they probably have it on the work sheet. Because I’m a frequent customer. No problem doing your own work. Been there done that. I’ve moved on. At my age I do what I want. Oil changes for the most part, not on the list.
Yeah the last year and a half has just gotten more nuts than everything was. Im only almost 50 and have done my own since I purchased my first ride. Its cheaper for me to do it myself even though its getting harder to get under there. I do keep impeccable records though :D .
Yes, there are service folks at dealers that should be in another occupation.
There are also some that could be having a bad day.
Otoh, there are also lots of owners that should be told to 'back away from the toolbox'.
One of my fears when acquiring used vehicles/machines is that it might have been in the hands of one of those owners.
Just because they are very good with the appearance care does not mean that are good with mechanical servicing.
Very true, and it bothers me to no end when I hear "car wash" guys try to speak as though they are mechanics, and vice versa.
Just because you polish shoes, it doesn't make you a cobbler.
  • Haha 1
Specifically referring to the crank/no start situation. I have a ‘21 sierra 3.0 and it was doing the crank/ start situation as well as a few other things. I took it back to the dealership for repairs and they said they had heard of it and there was a TSB on the issue. Their first repair is a shim on the reluctor wheel, if that works your good, if not they have to tear the motor down and do some other repair. They did the reluctor wheel shim on mine and it has been flawless since then, almost a year.
Don’t believe they are even doing that anymore. It’s just an ECU reflash now which gets rid of the issue.
If anyone has a lead on the software for programming the lm2 pcm, kindly reach out to me as I'm planning a custom build for the near future and we would really like to use this 2021 lm2 and transmission in this classic truck. Sadly it's not the same as previous duramax mods.. im sure someone has found a way by now. Again im just looking for help on the software sode of this, Please reach out, and thanks in advance, George
  • 9 months later...
How'd this go?
2 hours ago, Ronjon said:
How'd this go?
GOcustoms joined and made the post August 21, 2022.
Last visited site Aug 13 2022 -- the day after the original post.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
