I am building an 04 ccsb Z71 for offroad and possibly overlanding. I have Rough Country front fog lights, rear back up lights, bed lights, rock lights, Ham radio and soon a winch and possibly a 12v fridge. I already built a fuse panel where most of that runs off of. I want a second battery for deep cycling while the engine is off. I plan to add said battery behind the coolant resevoir on the passenger side. I have looked into some information for it but would like to get a more "first hand" knowledge base. So here are a few of my questions/concerns.
-Stock battery is 34/78 sized battery, can I fit a group 31 in the space as they are larger because of the larger AH rating?
-I am looking into a possible solar power addition for charging, but that may be down the road so with cost and specific charging needs I think Lithium is out. I might be going with AGM. Does this have specific charging needs? If I link the starter battery and secondary through a Voltage Sensitive Relay (VSR) will the vehicle's alternator be sufficient or will a dedicated charger be needed?
-Does the alternator only flow what is needed in amps? I see some set ups with an 80 amp circuit breaker to the second battery when I know the alternator can be around 120-140 amps. If this is the case I can get away with an 8 AWG wire instead of a 4 AWG? As the line traveled will be around 8ish feet.
-Should I stick with the 4 AWG wire in that it will help with the winches amp draw?
-Is the engine bay temperatures eliminate any battery types or brands that may be sensitive to heat?
-Any recommended batteries, set ups, things I may need to pay attention to or may have overlooked, any other advice?
Thank you for help as I know a winch will be a heavy draw and with all the add ons there will be a steady draw warranting a second battery, to not overwork or stress the starter battery.
Edited by myles archambeau
added another question
a second battery is factory installed with snow plow package and they just run a positive cable from battery to battery and add a ground wire from the auxillary battery to the block. if you are going to primarily run accessories when the truck is off you will want to add an isolator to the system so they just run off aux battery and the primary stays charged. RV stores carry them. the alternator has plenty of capacity to charge both bats and the voltage reg won't be affected. not sure how you would wire the winch if you use an isolator , you may not be able to run it off both bats without adding a switch to bypass the isolator. just add the circuit breaker to the load not the charging side of the system
also I would use batteries with identical ratings, I don't have a reason it  just seems like they will charge more equally.
I plan to use identical batteries. I may not be able to buy at the same time, but they will be. The voltage relay breaks connection between the batteries when the starter side goes before 13.3v, but when the truck is running and producing 14.8v the relay will make connection so I can charge the secondary and also draw when I use the winch.
Relay I plan to use
https://www.amazon.com/dp/B00WTAFR84/?coliid=I16QUNO8T7HO2X&colid=3BDGLR9PML5OD&psc=1&ref_=lv_ov_lig_dp_it
Battery options at the moment
https://www.batteriesplus.com/productdetails/battery/car-and-truck/chevrolet/silverado-1500/2004/v8-5.3l-770cca-optional/sli78agmdp
https://www.optimabatteries.com/products/yellowtop-d34-78
I am open to other suggestions and ideas, like if the group 31 batteries fit, which do I use? Thank you
These trucks are not designed to charge an AGM battery, sure you can use them just fine, they just will not last long as they could have.
Look up TP2, this is the code for a dual battery set up.  Batteries draw down separately but are charged together.  They ought to be the same.
@intheburbs Bill has done a detailed installation how to on other forums that you can easily find for the generation after yours and I think he also had TP2 on his old GMT800 Suburban as well.  He's a wealth of information to ask about such things.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
