So, I've got a 2015 GMC Sierra that I use to pull a trailer, with the NHT setup.
Very low mileage. Have not hit 45,000 KMS yet. But it broke on me last year and dropped an AFM lifter. Under warranty, but still cost me ~$1,500 as I was on holidays at the time and had to have it towed home, plus renting a 1 ton to get my trailer (underwhelmed by the GM 6.6L gas BTW). So I'm thinking I either sell it and buy a Ford with the Godzilla (don't want the headaches of diesel) or keep it and make it more bulletproof. Given the state of getting a new vehicle right now, and how unlikely it is I upgrade my trailer any time soon (RV market is similar to truck market, except the QA has gone to ******), I'm thinking it's time to dump the AFM properly.
So, what do I need to dump the AFM and build a reliable trailer rig? Options all the way up to a Procharger if it is useful. Bigger issue is finding a shop capable of doing it. I'm in Central BC, Canada.
I get that I'm talking cam and lifters, but what cam? And does the stock tranny (6spd) need anything? Truck has the bigger 3.73 gears, so I doubt I would upgrade those.
Any advice? Anyone done something similar?
Thanks for any input.
This is the minimum needed. Plenty of other vendors that offer kits as well; or you can piece together your own. Imo if your doing the delete you may as well go for a cam too. I would look into BTR, "Brian Tooley Racing".
https://www.texas-speed.com/p-5443-texas-speed-performance-gen-5-lt1-lt4-l83-l86-dod-delete-kit.aspx
Unless your doing this yourself, be prepared for roughly the same cost as a blower/install. 10k + cdn.
  • Thanks 1
Money, time, parts, and a good mechanic if you cannot do it yourself.
Edited by JimCost2014
******. Was hoping for about 1/2 that.
I came up with roughly $700 in parts if using a stock NON DoD camshaft. Then it would be the rest in labor to do the job. Obviously add like ~$200-300 for random gaskets, seals and fluids to complete the job.
Yeah labor isn't 1:1 when comparing USA to Canada; we get screwed over... I don't remember the actual hr's quoted but I do remember it's quite a bit more then the labor for a blower install (at least this shop).
They said that they have to pull the engine; that its just as hard if not easier than removing the rad and everything in front. I don't quite understand that, but then again they do a lot of corvettes. Probably have gotten good at pulling them.
Edited by M1ck3y
Yeah, if it was half that I would be going with a cam too. Depending on the shop you may be able to get it for a couple grand cheaper then a blower install. But then you start thinking about cost per horse power and a blower starts making more sense. But imo a cam would be funner
There's a lot of labor involved. When I had my lifter's/vlom replaced I think gm paid out around 6-6500 cdn parts included? and that's without replacing the camshaft. I think a good speed shop charge's around 150cdn per hr.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
