I have a 1986 p30 454 and I'm getting no power at all. I just put a new starter relay, new starter, new distributor, alternator, ignition Switch, headlight switch, and a new quadrojet carb. My mechanic had it running and when he left I couldn't get it to start again.  Any ideas on what it could be? I desperately need help!!!
I am assuming it turns over but not starting? Sounds like fuel problem with fuel pump, fuel filter or coil not giving spark to me See if it starts by spraying starting fluid down the carb.
So you're shotgunning parts at this thing for 4 completely unrelated systems ... WHY? Fuel, ignition, starting, and charging each have nothing to do with each other, but you need 12v to make the distributor create spark, you need GOOD FUEL to make it run, you need TIMED ignition, GOOD COMPRESSION, and AIR. You're missing one of these ...
You need a good battery, #1. You need good CABLES - BOTH of them, and good connections, not those crap emergency clamps from Advance Auto. You need 12v on the purple wire to the starter solenoid when in the CRANK position. If you don't have 12v there, you need to find out why. Switch bad? Wiring open? Shorted? You also need 12v at the distributor, and that 12v needs to be connected to the correct port on the cap - NOT the TACH port. There needs to be 12v there when the key is ON and CRANKING. If not, you need to find out why ... again.
IF all that checks out and it cranks, do you have spark? Is it happening at the correct time? Is it STRONG? Is that spark making it from the distributor all the way down the wire? Is the spark plug(s) good? If ignition is all good, what is happening at the carburetor? Do you have 5 psi of fuel at the carb inlet feed? Does the fuel smell like fuel? Run some into a clear glass container - is water settling out at the bottom? Does it look like orange juice? Is the carburetor set correctly?
We need answers in order to help you here.
Edited by Jsdirt
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
