We got code about 3 weeks ago. P0332 which was caused by pressure washing. We opened it about a week later and changed knock sensors with same wiring. Code came back up including gaskets. We opened it back up and changed wiring but not to the ACDELCO brand. So fastward to today the check turned on after running 17 miles. Got the P0327 and P0332. Should i open it back up and change wires or change both sensors and wires to original acdelco. Truck has 114k miles
Did yo use only AC Delco sensors. Did you
torque them to correct specifications?
Yes put only ACDelco wires and sensors in. Make sure you do the TSB about the silicone dam
Yea i used acdelco sensor but different brand of wiring. But just now we tested oms with miltimeter through the wiring harness plug and it’s getting 100oms. What should i do? And one of the new acdelco sensors that i bought incase i need to replace the ones it has goes down in oms from 100.
