I am in the process of having a slide-in camper build for a 2022 3500 SLE Double cab, Long bed, 4WD.  One question is what is the largest size that will fit to the end without the tailgate installed?
So if I were to create the largest box 5 feet tall that could slide into the truck bed and just come to the end of the bed with the tailgate removed, would it would be
98.27 inches long (The inside length of bed is 98.27 in. off a sheet the dealer showed)
and 50.55 in.wide (the inside width between the wheelhousing is 50.55 in.off the same sheet from the dealer).
Thanks
Edited by mobilelists
spelling
Seems like maybe you’ve answered your own questions, but I have my camper off my 2021 3500 hd srw right now and could take bed measurements if you’d like. I have the factory sprayed-in bedliner.
My concern is that the dimensions are actually for the case of the tailgate attached and closed.  I really need from inside the bed to the end of the taillights so I maximize the camper size.
This picture was taken with the end of the tape measure against the front wall of the bed at the floor. The top rail of the front wall extends rearward into the bed 2 inches. So your bumpers are against the lower front wall and the rail is 2 inches closer to the front wall of your camper. Figure accordingly. It’s 101 inches from the lower front bed wall to the end of the sheet metal behind the tail light  the tail light itself protrudes another inch.DE8E4BBD-2069-4C65-A92B-2FF1743D22F8.thumb.jpeg.c5f459e8abc10afb16f5a70dbe220059.jpeg
I’m happy to do measurements, pictures, or answer questions. It’s easy right now when the camper is out. I went through the same kinds of questions when I was trying plan an installation without the products in front of me.
I finally got the truck!
New question, what's the best way to route a couple 1/0 cables under the  truck to the truck bed?  Should I use metal conduit or loom?
Thanks
Thanks
You could use liquid tight conduit or even aluminum armor flex conduit. They would be the best of both worlds.
I’m curious why you are running such large wires to the camper.  Dedicated second alternator?
Edited by Another JR
I did order the 2nd alternator and battery.  In this case, the camper has a lithium system that can take a lot of current.  I am starting out with a 60amp battery to battery charger and if necessary there is room for a second.
I was considering thin walled metalic tubing but now that I actually have the truck, I see that the need to make a lot of bends to follow around the obstacles on the passenger side.  The aluminum armor flex conduit would make that easy.  I was hoping that there would be more gaps to thread wire ties but it is surprisingly free of holes along the run.  Just want it safe and away from possible contact with tall brush.
Thanks
Split loom will be adequate and reliable as long as you carefully route and secure the cable along the same path as OEM wiring follows on the frame to back of truck.  Do, however, make sure you provide sufficient slack to accomodate frame twisting and bending especially in the area between the cab and bed.
Edited by NWStever
I asked this question another thread but the answer may be within this group.  I have the upfitter switches installed and working.  Now I am trying to figure out how best to fasten a t-fuse holder and a relay in the engine compartment.  From there to the truck bed is not a problem.
Which locations and mounting methods have worked best for others? I am using a Blue Sea Systems 5502 Class T Fuse Block and a  relay.
Thanks
Been prepping truck for camper.  Amazed at the size of the truck.  For the first time in many years I had to get a soft fender cover to prevent scratching while reaching in to work on stuff.  I  find it a pain to get to some of the connections on the firewall short of building a platform over the engine.
To make it easier...does anyone know the thread size of the ground bolt on the driver side near the area that the upfitter cable feeds into the cabin?  The near mirror image on the passenger side serves as the ground point for the batterry.  It is very hard to access.
Thanks
Don’t know the thread size but just wanted to make sure you noticed the more easily accessible large ground studs outboard of the fuse box on the left side. I used one of them for the supply to my 30 amp dc to dc converter.
    btm
    btm
  • Who's Online   6 Members, 1 Anonymous, 1,531 Guests (See full list)
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
