2 hours ago, dieselfan1 said:
Speaking of calipers, the front setup is huge. Even the rear setup is bigger than k2.
I'm thinking about painting them red.
I also did this on my lifted 18 and it looked good
On a High Country? Maybe on a Trail Boss. In my opinion, Gloss Black calipers would compliment your truck perfectly.
  • Thanks 1
It does have the 6.2 like a Vette🤣😂
But seriously, I hear you . It's kind of in your face with red. Which was good on the lifted truck😁.
I need to do something though.
Those wheels will look way better with painted calipers.
I like gloss black but I'm all ears what color to paint them 👂👂
Yep, gloss black. 👍
You guys are right . I think black would look good.
What about the rotors?
You can see a lot of it.
I think the same gray would look good but maybe black also.
I did the calipers black.
Also painted the spindle and uca satin black .
Looks nice.
Tires came in this morning. Having everything  installed later today.
Not bad for time either. Order everything  on Wednesday, wheels and lug nuts, tires, tpms sensors, balance beads.
6 days later done.
Edited by dieselfan1
Looks nice.
6 days later done.
When it's done, we need pics and more pics! 😆
At the tire shop now
Sweet, but you're missing one more pic.  (A close up of the tire & wheel)  😉
Edited by Steve-2019
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
