4 hours ago, Hoginedgewood said:
Thanks for the awesome insight, I drive well under 10k a year, im figuring a toy hauler would be pushing 10k easily with 2 bikes. We're planning to rent a couple to see if we can justify a purchase of an rv, im definitely leaning 5th wheel. Probably 3 trips a year, mostly around 1-2k miles per trip. 2500/3500srw I think I'll see what lands close by, doesn't seem to be much to pick from. But I don't think I can justify the diesel.
Would be great if you could see the truck on the lot, to check the weight data tags.  Just watch your pin weight on the trailer.  When I first loaded out the 5th wheel, it was almost 3,400 lbs on the pin.  This 5th wheel has a washer dryer in the nose, and I had about 1,000 lbs in the front gen set compartment.
Most Toy haulers will lighten the tongue once weight is in the garage.   So maybe a couple of bikes along with a Turbo Razor. If you don't already have a SxS, and want to get the purchase past your "Chief Finance Officer", you might try this:
"But honey, we need the Turbo Razor in the back to keep the tongue weight in tolerance."
(let me know if that works for you. :thumbs:)
  • Haha 1
I would list out the load combinations (cab contents plus bed contents plus trailer tongue/pin load) you want to be able to haul, and  realistically estimate the payload weights with some margin added (maybe 500 lbs).  If all those numbers are around 3000 lbs or below, a 2500 should be fine and will have a better ride when empty. If any of those total payload numbers are above 3000 lbs, then you need to look at the expected truck payload capability and make a careful decision. If any loads are above 3500 lbs, you probably need to go with a 3500.
For me, at the time I ordered the truck I wanted to keep my options open to grow into a hard sided 9 foot camper like an Arctic Fox if I decided to go there. With that plus towing a boat the answer was clear. Now that I’ve had my 1800 lb FWC pop up camper for a year, I now know I will never get a hard sided camper. If I was reordering now I’d go 2500 for the better ride. However, at the time, 3500 was the right decision, and I’ll live with it. I still really like the truck, and I know at some point I’ll fill the bed with firewood or a water tank and be glad I have the one ton with its over 4000 lbs payload.  I can also set up my boat trailer with a heavy tongue load if I want even with the camper on.
If you plan to drive a lot unloaded it’s worth looking at this carefully rather than just defaulting to the greater payload of the 3500 because of the ride difference.
Edited by Another JR
On 5/16/2022 at 8:17 AM, sheath said:
This mirrors my experience.  The capabilities of a new half ton are very impressive, but there is just something about the stability of an HD with heavier trailers that is confidence inspiring.
by far a HD is better for hauling and towing even in moderate weight class.......stability, brakes, more agressive tow/haul mode, its a completely different experience than a half ton.....
very true specially with a diesel.  But after owning both no reason to spend the money if your towing 5k or less or doing 5-9k occasionlly.
Agree totally.  I was always skeptical about how much better could a 3/4 ton be as long as you're under the tow rating of the 1/2 ton.
Then I went from a '00 1500 to a '21 2500 gas.  I've since towed a 9k boat/trailer many times, and a 14k skid steer/trailer once.
I tell people it's like this:  A 3/4 ton will will be an easy, smooth, in-control experience at any load right up to its max rating at highway speeds.  A 1/2 ton will tow at its max rating, but it's not pleasant.
And since fuel mileage is in this thread as well... my lifetime "Trip 2" fuel economy over the 20.4k miles I have on this truck = 14.4mpg (mostly empty, mixed city/highway, includes all towing and hauling)
    Chris80s
    Chris80s
  • Who's Online   6 Members, 1 Anonymous, 849 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
