I have a 1992 Sonoma. My brother ran it out of fuel. We put gas in it and it turned over, then died. I can hear the fuel pump working and it's turning over, but it won't start. We replaced the fuel filter. Is it possible that the injectors are clogged, or stuck open/shut?  Any info would be greatly appreciated. Thank you.
Edited by Ldodge65
The fuel is also the pump coolant; my first guess would be due to the lack of fuel to cool the pump and associated parts some thing melted and now won't allow fuel to pass or you burned up the pump motor.
I know this seems elementary but have you verified you have a spark? Could you loosen a fuel line connection and verify you're getting fuel at the engine ?
Both DNA9656 and Spiney Norman's inputs are great points. If you havent got one, I would get a spark tester and check to see if your getting spark on all cylinders. Try spraying in some starting fluid, if it fires but dies seconds later, then I would say your pump has either gone out, or locked in place.
  I have heard some folks have pulled thier pump, and moved the fuel plunger, and it started working correctly again. But if your not getting fuel to the spider correctly, it will keep doing the same. I had to replace my fuel pump at 135000. It was doing same, firing and dying.
  Note if you do decide to replace pump, take off the bed, it is alot easier. Couple videos on Youtube..
18 minutes ago, dna9656 said:
Taking off the bed cause it's easier... ain't that the truth!
It was for me. 6 bolts, jack up bed, block it up. Change out pumps.
  • 1 month later...
Also the truck was run dry without clogged fuel filter/injector symptoms prior to the no gas in the tank incident so I doubt those are an issue. I did it on a Avalanche (no bed to remove) it would have been nice if GM put an access under the rear seat to change/service the fuel pump/filter assembly.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
