The reason they don't let you roll up remotely, is the same reason you can auto-down all 4 from the drivers door with one momentary press, and one momentary touch upward will auto close the front windows but you have to hold the rear window switches up to get them to come up.   It's liability, they don't want you closing the window on something or someone you didn't see.   Which is a little odd, because as many who have installed in-channel vents can attest if the window senses much friction it goes back down, but I'd imagine it's still enough force to do some nasty damage to say a kids finger, or a pets nose/ear.
I don't think I have the big center infotainment button I think that's where the descent control is, though I always thought it was funny that the button is so huge, they could have put 3 buttons there.
7 hours ago, 2016 Sierra Owner said:
The single button pictured above is on the 22 refreshed trucks.
The high trim level 19-22LTDs have it as well. I don't know the rhyme or reason for which trims got it or why.
I assume you mean High Country? My LTZ doesn't have it. Granted, I don't think Id want it either.
My HC has it. Your LTZ doesn’t 🤷‍♂️🤦‍♂️
I wonder what technology package it comes under for you to get the “monster “ button?
Must have been a Chevy only thing to? My 20 SLT doesn't have it either but then again I don't have space for a button like that being it's fully loaded X31.
Beats me on the package. I dont have space for anything more. Every button has something. Id assume, Id have to not have something I do to have that one. The far right, super large button on mine is hill descent.
  • Thanks 1
My 20 Denail doesn't have it. But this is due to the buttons taking its place are the Hill Decent, and Running Boards buttons.
Pretty sure it's just a filler feature that gets removed if something more important goes there. (Ex ZR2 and AT4X Lockers)
Noticed on the Refresh the Running Boards and Power Outlet buttons were removed (Boards to screen and Outlets always on now). So now either the Lockers go there, or you get the window roll down as a filler instead of blank buttons.
Edited by claw2791
Interesting…..Power Running  boards are the only option I didn’t get on my HC. Didn’t want them.  Have never liked them. Makes sense though, but my wife and I still can’t get over how large and awkward it is.
Yeah they were standard on mine. Could of managed without. They extend backwards to the bed to help get to it as well as the normal step.
The button is kinda multipurpose. Hold disables them, one push extends them, and another has them go backwards towards the bed. Mainly just use the button to extend them at carwashs since they usually sit covered.
Considering all that button did, can see why they just moved it to the screen for the boards on the Refresh.
  • Thanks 1
100% on the half-ton power running boards.  The look bulky and foolish to me. The HD trucks have nice, slim power running boards that tuck up under rocker panel. I enjoyed those and rather have those or stationary boards instead.
Not for me. They go out after a few years and also don’t product the whole side of your truck from rock chips. After 2-3 years the sides of your truck looks like it’s been sand blasted.
My SS Trailblazer didn’t have running boards or splash guards and it had to go into GM to cover it under their TSP bulletin  rock chip repair.  Never again will I own a truck or SUV with them. Just my 2 cents. Can’t stand rock chips.
Your preference is the standard mount running boards, not automatic? I can see how some people prefer that. Depending on the vehicle, it can also change the appearance/ground clearance aspect. Some look better with running boards and some look like they drag the ground.
Edited by ShotgunZ71
Yes. I like my standard boards. They also go length of cab to wheel wells. Make for easy drying off after a good wash.
Get WAMS and then you can do windows down AND up from the keyfob.  Great for those rains you didn't see coming
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,304 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
