Truck began to start taking a few extra seconds to start up, then finally wouldn’t start up on me. Got it jumped first time no problem. Now it won’t start at all. Put in a new battery, alternator and starter and still nothing. The 40amp IGN A fuse blows every time I turn the key. Still getting power, just won’t start. Any suggestions or help would be appreciated.
When did the fuse start blowing? After you put a new starter in? shakenfake is right, check all the wires in that circuit and make sure there are no shortable or dumpy connections. Worth your time to clean them all up.
Additionally, if that fixes the fuse issue but not the no crank, no start problem there are a few things you can do. First is put the key to the on position, do you hear the fuel pump prime? You can swap equally rated relays around like the fuel pump relay in order to take the relay out of the equation. Another one thats annoying is the immobilizer ring in the key tumbler/ignition switch. The three pin connector on the top of the ignition switch can get touchy and not allow a crank and start. You can pull that connector out and clean up the contacts, and also jam something non conductive in the connector to try and wedge the connector tight in the receiver.
If you have a multimeter, even a cheap one, it can help solve this whole issue.
I appreciate the responses and help from y’all.
I can’t get the fuel filter off, the connections have pretty much rusted together.
I can hear the fuel pump when I turn the key and I also hear a “clicking” in the fuse box when I actually turn key all the way and that’s the only noises/ reactions that I get. I don’t know for sure if the fuse blew after I installed the new starter but after installed I checked and it was blown, I then replaced it with a new one, tried it once and it also blew. The first time I tried starting it up after I finished installing the new starter it did sound like it was going to turn over but then I heard what sounded to be a metal grinding metal so I turned key off quickly.
Sounds like the starter install didn't go right. I'd pull it off and re-inspect.
One problem at a time, a no crank condition will not be resolved by the fuel system, get the cranking condition fixed, then move on to no start or hard start.
Edited by asilverblazer
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
