I had to take my 2022 Silverado with the Duramax into the dealership due to check engine light on and they also said there was a recall for the shutters. After they got it into the shop and looked they said in the harness for the shutters a wire was pinched that was causing proper signal for the shutters to open and close. I ask how they fixed the issues and their response was, "We moved the harness to the proper location and moved the wire so it was not pinched and all problems went away." My concern is the wire was pinched now they have moved it to me that has weakened the wire if it was pinched bad enough to not get the proper signal. They claim they did not splice it which personally I am 100% against splices in main wiring harness for a permeant fix especially on a brand new truck. So I wanted to just see if anyone else has ran across this issue yet? I am going to have them show me what harness they moved and verify they did not put a splice in the wire before I take the truck off the lot.
This is the recommended fix from GM:
The fix: dealership service technicians are instructed to add a tie strap to the wiring harness, which will secure it to the vehicle and ensure it does not contact the active grille shutter while it’s moving. These repairs will be performed at no cost to the vehicle owner.
https://gmauthority.com/blog/2022/07/chevy-silverado-gets-service-update-for-aero-shutter-wiring-harness-issue/
Thank you, my only concern is still there was a pinched wire that was causing all kinds of issues in this wiring harness. My main question is shouldn't the harness be replaced if there was even "just a pinched wire" to prevent issues down the road from that wire being weakened?
If the wire was pinched and there is wiring damage, the service "recall" is to replace the aero shutter assembly and re-secure the new wiring.
I would think they should but the dealer told me and I quote, " We moved the harness so the wiring was not pinched anymore to let the wire transmit proper signal, and that was the reason for all the check engine lights for the ECM and TCM was the wire was pinched enough to not let the proper signal to transmit through it."  To me if a wire is pinched that bad then it should be replaced and not spliced. Am I over thinking this issue?
Yes, they have guidlines to follow and thats what they do, some may be pinched alot more than others,road conditions and driving habits, stops,starts etc could have a lot to do with how hard the wires are pinched if they are pinched. Some may be pinched and others may not be.
They are not going to replace parts if not needed. the word pinch itself is a word that can have many degrees of pressure.
Let the dealer perform there job.
As a former service rep for a global company, pinched wires may not have any internal damage. I've seen it several times There are a few ways to verify that too. My question is how did they know a wire was pinched if it's in a covered harness?
My issue would be that they are treating you like an idiot.  A wire carrying electricity cannot have the electricity stopped by kinking or "pinching" the wire.  Electricity don't give a damn. If that truly was what caused the money light to come on, then it was not "pinched", it was severed.  They are talking about it like it is a washer fluid hose or something.
I would not be worried about them splicing it.  If the ever splice fails, then the money light will come on again, and then they will replace the harness or the whole shutter assembly.
Do you have the actual TSB for this?
I had the CEL come on tonight and the fans are acting weird. Thinking this could be the issue. I have U0284
    • Black bumper and the later years Z-71 style color matched grille.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • // Thank you, also for your  response. More information is always good. This 2013 GMC is most likely my 'forever truck"-I'm 77 and retired...and truck only has 42K on it-very clean-so I try to keep it that way.  Tks again for your  response- glenn
    • I started my install this weekend. Everything was pretty straight forward but I ran into one issue with running power through the firewall. The nipple grommet on my High Country already has a small harness running through it - has anyone else ran into this issue? And on the engine bay side, does the wire basically just penetrate the factory wiring boot? I did this on my '22 Trail Boss and it seems much easier but thats been a few years. My other thought would be possibly drilling a new hole adding a rubber grommet just to the lower left of the factory hole. Thoughts?   Has anyone used a T-harness off the Bose amp and obtained power from there? It seems a little odd that such a small amp needs 3 power leads
