On 2/16/2025 at 12:36 PM, customboss said:
@Grumpy Bear rip it up and spit it out.
Man that was over 250 Characters. Attention span exceeded. :crackup:Kidding 😉
First impression on a light once over reading. I'll go deeper as I reread and digest.
There is allot of good information in this booklet. There is a minimum of "not quite on the money interchange between the information and the application". But some does exists. It's a sales tool.
This is one of the few post I've read that makes note that not just a particles size matters but it's HARNESS as well. And this is one of those interchange moments. 🤔 Most of the 'matter' in oil is "Relatively SOFT nucleated carbonaceous materials that have amalgamated. That is they are softer than the things they are trying to abrade. At least at reasonable OCI's and in a healthy motor. Elemental carbon is about 0.5 on the Mohs scale while gray iron is about 4.0 Mohs (softest cylinder bore). Silicon however is 6.5 Mohs (air born sand). Keep those air filters sealed and in good service.
Still the point, if a bit misapplied, is still valid within the 'stated context'. I have to reread the 'reference a few more times' cause it seems to imply that most of the debris over the oils life cycle is introduced by the incoming combustion air. True in 1925, not in 2025. More the point is that the device will rid you of something a cartridge will not and while true on the face of it, would only matter if it were present.
It also agrees with the earlier GM wear studies of cartridge filters using a similar method. Introduced know quantities and compositions of materials.
Important, BOTH studies introduce particles for the express purpose of wearing the components in a rapid manor to accelerate the study. Not a lot of aluminum oxide or silica generated in a motor.
That said both studies indicated similar rates of wear at similar cleanliness levels and actual road miles have born both to be true. So I could pick some nits (just did) but on whole....Yea, that was a good'n.
  • Thanks 1
Wait there's more here:
Focus more on rings study, I can't remember but we saw something there. The additive was developed for that in post 2 on CMOC
Read the supplied CMOC article. Noted the 'Discussion' section after reading. They raise some valid concerns about the study and yet there seems to be some 'there there'.
In the discussion the second push back concerned the amount of wear vs the length of study. As I noted earlier 'accelerated rate' studies are common and have a basis in reality but they do look WEIRD :crackup:
So this third study echo's the first two "directionally" and I know how you feel about that word "Directionally" but it is a good word when we compare apple to oranges. That is, fuel, oil and CMOC which brings me to a question you will be in a better position to speak to and that it......
XOM and Shell's Premium fuel 'friction modifiers' which Lake Speed and the Total Seal Team have evaluated and confirmed after the Shell study...are these in addition too or a part of CMOC's. Kind'a get the idea they are not the same but...... A bit past my sell date 😉
Now, that said and noting these CMOC's are "friction" activated and have a "finite life" due to concentration, thus have a critical OCI highlights the need to be vigilant in our oil maintenance programs and make wise fuel and operating condition choices.
Between these two exchanges I would offer this....
There is so much more that could be done and yet, due to greed, is not. We know "Directionally" which way to go. Which fluids to use and how long to use them. We know what 'else' we could be doing and what effect those efforts will have. We know and yet we don't regardless of the proof set before us because??????
It takes so long to reap the reward we grow weary and give up.
I learn on my first fuel stop with my Enfield Bullet 500 which took the better part of a hour that people LIKE the idea of buying one for a lifetime and yet have no patients for the effort it takes to reap that result. See how long it takes at the dock to fill a Crist Craft or a 1952 Cadillac 62 and you will understand how people value 'beauty' and how little patients they have to hold it in their hands.
The rest of the story?
Studies like the ones under discussion are done in environments and under states of construction we do not experience in production machines for the intended purpose of accelerating the study to a manageable length and cost. Wear out is done in hours in limited cycles and not years and hundreds of thousands of miles. Studies are meant to make a point and deliver a result that you get to reap the benefit of for a very long time.
Just an interesting link with some insights into current ring coatings and experimental yet to be.
http://pnrsolution.org/Datacenter/Vol3/Issue5/53.pdf
link ain't working but could be my brave brwser. CMOC was a code for something I can't remember. I have suspicions but with current brain issues I can't remember and my reading comprehension is impaired.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
