I have two questions about the 2022 refresh and  it sure where to post them.
does anyone know if the Denali has passive keyless entry? Where the truck lights up and doors unlock as you walk to it with the key.
also, are the seats in ultimate any more comfortable than the other Denali trucks?
I don't think any GM truck (not SUV) has passive locks. You still have to push the button on the handle. As far as the seats go. I think the internals are the same the leather changes is all you get there.
Edited by 2016 Sierra Owner
2022 refresh OM:
Keyless Access Operation
The Keyless Access system allows for doors and the tailgate to be accessed without
pressing the RKE transmitter button. The RKE transmitter must be within 1 m (3 ft) of the
tailgate or door being opened. If the vehicle has this feature, there will be a button on the outside door handles.
Keyless Access can be programmed to unlock all doors on the first lock/unlock press from the driver door. Keyless
Unlocking can also be turned off.
I would say based on my experience with my new ultimate  vs my at4 i had yes the seats are way better but that's due to the fact you have way more adjustment 16 way vs 12 way. You can move the lumbar to the correct spot and you also have shoulder, back bolster adjustment, plus the massaging feature.
For the unlock like others have said you need to push the button on the door
One thing I don't understand about the programming on the trucks is why the interior lights and puddles lights don't come on as you walk up.  My 2022 Tahoe Z71 would turn on the interior lights as I got close to the vehicle (not the puddles lights unfortunately) before I unloacked it, but my '22 AT4X does not.
I'm also missing the footwell lighting and the glovebox light that was mounted to the lid instead of lower in the glovebox.  The Tahoe also had a small sliding door to the right of the center stack for sunglasses as well as an unlock button for the rear doors.
I like my new truck, but it feels like there were a number of corners cut considering the $80k asking price.
pretty sure it is due to the chip shortage so they removed whole bunch of things. my 2020 AT4 has buttons for all four exterior handles.
    • It is a company truck. Not under warranty. Both companies I’m involved with usually buy trucks that are discounted when looking. Except what the owners drive. Being retired and minority owner. I don’t drive a company truck. If they have the new GM gas engine it would be in a service truck.
    • Update!   Had the dealer look at the issue. First tech says no problem?? I said there was no voltage on the brake terminal on the 7 pin connector! He said he did not know what pin I was talking about. So they bring out a seasoned tech and I explain to him. He attaches a VOM and has me push the brake, and sees no voltage!!    Tom, the seasoned guy says lets go back to my service bay and look closer. We discover thru his on line system that the controller is a "smart controller" as it needs to detect a trailer connected before the brake voltage is allowed to the 7 pin connector!!! He also showed me a GM bulletin stating some trailers with LED lights have such low resistance the controller wont recognize them!!! I was thinking WTF, but thanked him for bringing me back into the service bay and explaining this all to me. He also plugged in a trailer simulator and it showed the brake controller was indeed working.   After my dealership visit I hooked up to an older camper with standard 1157 lights and the truck did connect and the electric brakes worked great!    Not to sure what I have to do with the equipment trailer with LED lights, I cant tow it with no brakes.   Why did something so simple for many years have to get so complicated!
    • Do find out as that would be interesting if they have been using any L8T engines or for that matter have been running any of the Ford gas 7.3 to see how they have been panning out.    I assume your nephews engine replacement was on his dime as the regular warranty would have long past unless he had some form of extended warranty that covered such events. That shows though and may depend on the year of the build that failures are occurring with the valve train well beyond the warranty distance and more than likely so will others have that sneak up on them.
    • I realize this is an old post and its probably been talked about since then on this forum and I may have mentioned it myself but the Chev multi flex tailgate on the HD trucks are all aluminum so there is that one item that I am aware of on a current GM HD truck that is aluminum but if its the standard tailgate then its still a steel unit as far as I am aware to current 2026 model year.
    • I am surprised it didn't pop back up some just in time for the end of school/summer holidays and July 4th time period. Here in Alberta it hit its low coming off the high back a week before the end of June or so and has been creeping back up some and would equate roughly to around 20 cents per gallon increase. Of course there are various factors and one is the games they typically play with wanting to capture that holiday vehicle movement but also our government directly causing our Canadian dollar to drop ( a polite way of explaining the real picture ) causing our prices to go up rather than continue down like it should have, and even though we are sitting on the crude.
