depends on your truck, if it is an ior system, then aftermarket is the only thing you can do. contact wams with your vin number, Chris will let you know what's available
On 12/4/2022 at 11:56 AM, Randall Sizemore said:
I just purchased a 2020 Chevy Silverado RST and I want to add a front camera. How do I know if it can be added to my current system.
Hi Randall
I searched this and then  asked this question. Short posts and trailer hitches sticking out are impossible to see.  OEM Cam is too complicated and expensive. Finally. I got one off Amazon at a decent price. Wolfbox G900 for under @200 US.
I installed it under the license plate holder. Drilled a hole to fit it. Barely noticeable. This Display clips over the rearview mirror and is very clear.  Cool thing about this is you can have a split screen with ground view and forward as it's a dash cam too. It also toggles up and down with a swipe of your finger. Easy to install. Just one wire through firewall to cam, from rear view mirror. Then power cable from Acc plug to display.  I was quoted $600 US to have it professionally installed.
I can see the paint markings on the ground now, and have a dash cam recording in case we get cut off and ditch.
5 minutes ago, Randall Sizemore said:
Do you have pics?
Not yet, can post tomorrow maybe. Check out Cam on Amazon. I glued mine into place under front bumper, below license  plate. It is clear, touch screen, swipe to change views. It's meant to be a rear view Cam...but we have that already. I like hoe it pans up and down with a swipe of  your finger
On 12/6/2022 at 4:49 PM, Randall Sizemore said:
Do you have pics?
Here are some pics, video won’t load
it can zoom down to see something this close, or pan up with a swipe of your finger
the drill is very low!
pretty easy to install. Parts fit under the Onstar plastic housing at rear view mirror
Edited by Mike Duhaime
2 hours ago, jerracing1 said:
That badass , do you have a link
On Amazon.
I got the Wolfbox 900
you don't need to wire into reverse light . The cam is always on. I have a kill switch to cut all power if left on one week at airport.
I think I have an idea for this..
There is a mod for the illuminated mirror in which the camera/spoiler is swapped for those who have standard mirrors. Couldnt you just remove the camera and mount it to the front of the truck?
That way you can push the button on the rear view mirror and see the front of your truck in the rear view?
Anyone have any ideas on this?
On 2/15/2023 at 2:30 PM, DHBWA said:
So you lose the original rear view unless you power off?
yes, just touch base switch to blacken display and it's a reg rear view mirror. It still records. Just touch screen anywhere to see cams.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
