Because I want to take the one off my 02 Silverado 4.8 Ls and put it on my 2017 Silverado 1500 LT 5.3 that's y I'm curious
Not really.
The y-pipe will not bolt up at all.
Technically the only thing you could do is chop the cat off that pipe and the exhaust on the 2017 truck, then weld the cat back into place. But it's still possible that the 2002 cat converter does not do enough for the much newer emissions requirements on the 2017 truck. So the check engine light could come back on.
Is it molten or loose? Or do you have fault codes?
The cat should normally last until the car is gone or the converter is stolen 😀
Check engine light blinks and when the tranny downshifts the exhaust vibrates really bad only when dropping into a lower gear it was giving me a code of engine misfire on 3 and 5 so I replaced all ignition coils on negative side all new spark plugs driver and passenger cleaned my throttle body and reset it but I haven't tried changing my 02 sensors just need some different opinions on what it might be causing my check engine to blink that's usually something serious
What are the codes in the truck?  Not a description, but the code number.  So say its P0303.
A cat y pipe would not be compatible from a 2002 to a 2017.  Different emissions requirements, different exhaust layout.
That does not sound like a catalysator issue. I think you should start with a systematic fault analysis instead of just changing parts. Otherwise you probably end up wasting a lot of money.
As @newdude said, what are the fault codes?
I have no choice I had a full scan done and the only thing that came up was a engine misfire on cylinders 3 and 5 and I was told to change the ignition coils and wires so that's what I did but the engine light keeps coming on and blinking from my experience that indicates a bad cat maybe I should perform a smoke test to see if there is a vacume leak somewhere just hoping someone out there might of encountered something similar
A blinking Check Engine Light indicates only misfires. Nothing todo with the catalytic converter.
There are a lot of reasons for misfires. Bad plugs, bad ignition coils, low fuel pressure, bad injectors, broken valves, lifters, compression issues and so on.
I really think you should perform a step by step fault analysis.
I thought this was a place we bounce ideas off of each other y am I being questioned like I don't know what I'm talking about instead of telling me where you think I'm wrong which I'm not try helping me out it has everything to do with the cat for example what steps would you take if you had a deep scan of your vehicle done and you came up with one code so you think you have the problem pinpointed well after repairing all areas that have to do with that code your problem still exists what would you all do that's all I'm here for advice not who's wrong or who's right
    • A little girl said her prayers every night before bed and she asked G d to watch after each person she loved. One night she forgot to pray for her babysitter and her babysitter died. A few days later she forgot to pray for someone else and they died. The next night she forgot to pray for her dad. The next morning her dad was terrified. A bus almost crashed into him. He almost fell off a fifty foot ladder and almost wrecked on the way home. When he arrived home, he said I had a terrible day. His wife replied, “You think you had a bad day? My aerobics teacher died during class.
    • Nice! I had one here, once. The car dealer I used to haul for stopped by with it. That was over 10 years ago now. Those are SUPER rare these days, especially up here! Never even see them at car shows anymore.   https://postimg.cc/0rvcNZ1W
    • I remember watching one of the auctions on TV. It just happened that they had two little red express trucks. My brother bought one new in 1979, still has it. So I hung on to watch them cross. The retro redone example brought more bids and went for more money than the original one did. My brother has redone his 3 times and raced it. He’s now in the process of making more tame for cruising.
    • I always upgraded the suspension and steering components - bushings and ball joints, and had older cars that I could out-corner ANY modern car with. I used to be able to take my '78 Cutlass on off-ramps at stupid speeds and make the sharp MA corners without even squealing the tires. So much fun. My '72 El Camino must've had work done by the previous owner, since that thing seemed to handle even better than the '78.   I think the suspension & steering on the '72 was much more advanced than the '64, so that probably just made a good system even better.   I'm the same way with vehicles. I hate having to worry about the paint on my '93 W250 Cummins. I'm not used to that, lol.   https://postimg.cc/mzKr55sY
    • BEAUTIFUL!! That a Cutlass F85? Or 442? My side-ID skills are lacking thanks to failing memory, lol. Love that color & year, too!   Yeah I was never big on entering my own stuff, but I always liked seeing what everyone had, the rare models, and what's been modified. That was always fun. These days I have barely enough time to do what needs to be done at home.    Oddly enough, here in MA there are more car shows than ever in history! You'd think up here it would be dead, but it's bigger than EVER!          Took the 940 for its maiden voyage with the carburetor. At first I couldn't get out of the yard! This originally had the "Bosch" system (our other 940 has Regina - single fuel pump in fuel tank, and space-age-looking ignition coil on driver's fender) - that has dual fuel pumps. One in the tank, and one under the center left of the vehicle. I had unplugged the external one thinking I wouldn't need it with the carburetor ... but the way I have the pressure regulator hooked up, 90% of the fuel volume is going back to the fuel tank, so cranked all the way down, the regulator is only supplying a hair above 3.5 PSI to the carb. Turns out the in-tank pump (15 PSI alone, instead of 45) couldn't handle the load. Plugged it back in and went for a rip. Ran great!   Throttle response is always amazing with carburetors. ZERO delay that no FI system can reproduce. Also fires up in half the crank rotations as before. Low end power was DRAMATICALLY improved. There was an ongoing lean issue with the FI that I got tired of figuring out, so this is a MASSIVE improvement! Above 50 MPH on hills it feels SUPER weak, though. This is more than likely due to the timing not being advanced enough by the computer, since it believes there are multiple failures. I can live with that through the winter. Will keep me from passing slowpokes where I shouldn't and getting speeding tickets at least. 😁
