On 12/21/2022 at 4:31 AM, Victor Brown said:
Just curious is the catalytic converter on a 2002 Silverado 1500 Ls compatible with a 2017 Chevy Silverado 1500 LT
A cat only plugs from misfires. If you have that all sorted out, then change cat. There are expert welders that can change your cat, weld it in place. it's often done, you just have to locate good muffler fabricators
On 12/23/2022 at 7:53 AM, Victor Brown said:
I thought this was a place we bounce ideas off of each other y am I being questioned like I don't know what I'm talking about instead of telling me where you think I'm wrong which I'm not try helping me out it has everything to do with the cat for example what steps would you take if you had a deep scan of your vehicle done and you came up with one code so you think you have the problem pinpointed well after repairing all areas that have to do with that code your problem still exists what would you all do that's all I'm here for advice not who's wrong or who's right
Well.  Plenty of us here are more than willing to help.  It gets a bit harder when those that ask for help don't provide enough detail or the right details.
I know that I asked if you have the actual codes and could post them here as the codes are a diagnostic aid that can help others and myself on here try to steer you in the right direction.
Instead, you seem to be getting defensive and are now quoting a random googled source.
A bad catalyst will NOT cause a flashing check engine light.  A flashing check engine light indicates a failure or issue that can lead to damaged catalysts, not flashing light = bad catalyst.  If you keep driving it flashing?  Yea, you can get to that point.  If you don't have a P0420 code or P0430 code, its 99.9% not a catalyst issue.
So.  What were the exact codes you have?  Not just "misfire on 3 and 5", what were the code numbers?  Was it more than just those two?  Do you have any knocking, tapping or ticking noises?  Bad camshafts occur in these engines sometimes and bad lobes can cause misfires.  3 and 5 aren't AFM cylinders however there has been valve spring failures on these engines.
The 14-19 trucks are known to have fuel injectors fail.  Bad injectors can for sure cause an active misfire.  Have you had an injector balance test run?
Edited by newdude
  • Like 6
  • Thanks 1
I'm with Newdude.
Just because you changed the coils and wires doesn't mean you fixed all possible missfire problems.  If the cat is bad it's because of a missfire.  The cat is down stream of the  engine and probable not cause of a missfire.  I will make it run rough but not cause a specifice miss fire in 3 and 5 only.
You need to go get a cheap scanner and read your codes again.
It could be an injector which is common.  And pray it's not a lifter.
If you converters were failing or have failed, your secondary O2 sensors would detect this and throw the appropriate DTC code. A misfire is not going to be caused by a bad converter and especially not only on 2 cylinders.
As already stated, you need to look at spark plug, ignition coil, plug wires, injector etc.
I don't think we are going to find out anything further on this subject. It appears that @Victor Brownmay have taken taken his ball and gone home. He hasn't been back since Dec 24th. Maybe he will prove me wrong???
Edited by mikeyk101
    250.3k
    chfkief
    chfkief
  • Who's Online   4 Members, 0 Anonymous, 1,508 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
