2 minutes ago, Graham1992 said:
About to roll this truck off a bridge, it's bad enough you can't have open drinks in the cup holder on the interstate/parkway.
Angle of the driveshaft since it is lowered? Had a 04 that needed shims to get the right angle, was violent at freeway speeds until they found the right angle.
Just a guess.
Just a guess.
I put money on this if I had to.
  • Thanks 1
On 2/3/2023 at 8:22 AM, Graham1992 said:
I've had these MRR T228 for 2 months now and have been at the shop 4 times to diagnose a shaky wheel/tire combo at highway speeds. I had Toyo proxes st tires and went thru a combination of 7 different wheels and 7 Toyo's before the shop ordered some Nitto's the same size. The Nitto's were put on and the truck STILL shook so we put the stock 18's on and the truck drives great, NO SHAKE. Any help? MRR is to the point they almost don't wanna help and I'm having to look into new wheels. Anybody went thru the same thing?
Off the original topic, that is a GREAT looking truck, makes me miss my 04, same stance and looks. Victory Red with 20's, matching painted hard tonneau cover.
Thanks, I'm in love with how it looks, i want maybe an inch lower and I'm good. I want a paint matched cover but the price scared me away for a while!
The tonneau I had came with the truck, lots of dealers used to lower or lift trucks, then you just bought it with full warranty.
It was PIA when I first bought it, the lowering kit on the truck just did not work as advertised, ending up having to have the back half of the transmission housing replaced (tail shaft area), it would vibrate and bottom out so bad, it cracked.
I finally ended up getting the driveline shimmed (shims under the leaf pack, rotating the axle), replacing the drop shackles with factory ones (just a static drop), and having the wheels rebalanced. After all that, I still had a rough 3-5 drop, never bottomed out, or vibrated again. Could tow and put a normal amount of weight in the bed.
Good luck, the problems are hard to find when you alter the factory specs (geometry) of the suspension.
Edited by JimCost2014
Just a guess.
Going to make sure this isn't what they've already done. I know they mentioned shims when they were trying to figure it out.
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
