I've had these MRR T228 for 2 months now and have been at the shop 4 times to diagnose a shaky wheel/tire combo at highway speeds. I had Toyo proxes st tires and went thru a combination of 7 different wheels and 7 Toyo's before the shop ordered some Nitto's the same size. The Nitto's were put on and the truck STILL shook so we put the stock 18's on and the truck drives great, NO SHAKE. Any help? MRR is to the point they almost don't wanna help and I'm having to look into new wheels. Anybody went thru the same thing?
You need a shop with a road force balancer. With that not all the shops that have them use them correctly. That balancer will tell which wheel or tire is out of round.
They've mentioned they do, yes,  and they got them to the point where the wheel and tire spun correctly with the Nitto's on on the balancer, then they put them on the truck and it still shook. So the way he explained it was its correct on the center cap and off balance on the lug holes. That where I'm at out.
Ok well if that Truly is the case all you'd need is a hub centric ring. I would start by getting a micrometer and measuring the wheel hub bore and truck hub.
1 hour ago, Snowcamo said:
Could also be wheel hubs gone bad.
Doesn't seem likely that stock tires and wheels would correct it. Unless they are able to mask it enough to not be noticeable.
Try, keeping three factory tires and wheels on and put 1 of the MRR set ups on one at a time to try and see if there is one or more of the MRR's causing the problem.
Inspect the hub mating surfaces for debris or manufacturing defect preventing the MRR from mounting properly.
Make sure the lug nuts aren't bottoming out on the studs before tightening to the wheel.
They would correct to the point it's not noticeable. Only due to less weight. I can put first hand experience with it as my truck came with 17s factory.
Pull a wheel off and look at the brake rotors.  Do you have any of these tinnerman nuts/clips on there?  The little bronze colored ones in the picture below.  If you see them, take them off.  They can cause an imbalance with aftermarket wheels and GM accessory wheels.
READ HERE - MC-10162155-9999.pdf (nhtsa.gov)
Torque and Clamping Force - Tire Review Magazine
Edited by newdude
  • Thanks 1
Also.  Center bore would be worth checking.  OE wheels are 78.1mm and MRR has those T228s at 87.1mm so I don't know if its actually larger?  Or did they just transpose the digits?
  • Thanks 1
I would figure at some higher speed you’d notice eventually but I could be wrong.
I’d does have the rings on it yes.
Update, the new running theory is it isn't the wheels, it's the driveshaft. Dropped the truck off to get the driveshaft pulled out and balanced and will come back. I was on a long interstate drive on my 18's and started to feel it very lightly compared to when the 22's were on, so the larger tires were taking most the shake out.
  • 3 weeks later...
Sorry for the delay, I've not had the truck in almost a month. 7 wheels were replaced, 6 tires were replaced before changing brands from Toyo to Nitto. All the wheels/tires and now showing they are good and don't require any weights at all. The owner of the shop even took them to another shop to use another machine just to check that off as well. The driveshaft has been balanced and the shop "checked the rear end" and it showed true, yet issue is still ongoing. The wheel hub surfaces are flat with no washer on lugs. The truck still shakes at the same speed, about 65-80 or so, as well as at a lower speed you can feel the truck jumping or hopping at maybe 15-30 mph or so. The only other thing I can think of is maybe torque converter? As I've read that a lot but I thought that was more of a 6.2 issue. Any other advice? This does not make any sense to me....
About to roll this truck off a bridge, it's bad enough you can't have open drinks in the cup holder on the interstate/parkway.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
