I can understand that from being in the North for the first 25 years of my life.
As I mentioned, I miss it, but only a bit.
Still, my Mom lives in Colorado and I love visiting for the incredible vistas.
I'm a bit jealous of those who can walk outside, take a drive, and enjoy the mountain views.
I suppose, however, we are digressing from the topic but I don't mind. :)
Thanks for all of your input.
I'll update soon!
On 2/25/2023 at 11:20 PM, MikeBMW said:
I'll have to recheck my order but I think I have each one on the way soon.
Thanks, Jim!
Mike, where are you sourcing parts?  I placed an order for a few of these items and was told they require special ordering and will hopefully be ready soon. I went through tasca as they had a thermal bypass valve in stock that I needed. Turns out they had none of it in stock, and the TBV is on backorder so I cancelled that part of it...  May have time to cancel the rest of the order and get all of this at once..
On 2/25/2023 at 11:11 PM, JimCost2014 said:
All right, now I get it. There was a member who replaced this before, and now I remember why he took out his taillight.
You need number 5, maybe 4 to be safe, and probably not 3, maybe just to be safe? They all are connected, but through the bed of the truck, and the diagram does not show that. So, 2 and 3 are accessible inside the bed, then 4 and 5 are inside the fender well.
Thanks Jim!! I was looking at that metal piece the bushing goes in and thought it may be an issue too.  I think I'll try and order these and see where it gets me. I ordered all the bushings but no idea when they may get here.  Luckily it still closes fairly easy, its just the going down that is tough.
Edited by Skeeter McSkeet
deleted....another duplicate....fat thumbed this post button apparently
duplicate
deleted....duplicate....will try life again tomorrow, my goodness LOL!!
duplicate
Number #3
Number #5
I usually go to GM Parts Direct ( https://www.gmpartsdirect.com/ ) for miscellaneous parts and part number identification.
It's a bit higher in price but I always seem to be able to get what I order within a week or two.
If I can find a part available somewhere else, and it's at a lower price, while still being genuine GM, I'll buy elsewhere.
Update on my experience with the tailgate.
I bought the new hinge and dampener and plastic bushing, seemed to make a difference, still not soft open.
I thought about the torque rod and ordered one.
Well, I inadvertently bought one for the previous model years, but it took me a long time to figure that out, way longer than a sane person would do.
I spent an hour trying to make it work, then, I looked at my old one and the diameter of the torque shafts were different.
My original one had a larger diameter and that's why I could never tighten the incorrect one for torque and tailgate lowering.
Anyway, I reinstalled the original torque shaft, tightened it back up, and, now, it's back to like new! In the interim, I ordered another, thinking my original one was failing, somehow.
I dunno why, but it seems removing it and reinstalling it brought it back to life?
Well, I have two torque tailgate rods now, one for the K2s and one for whatever generation that was prior.
I'm gonna go bang my head up against the wall for a bit...
Edited by MikeBMW
grammar
Thanks for the update!! I just got the parts last weekend and have yet to install, I did not get the rod though.  Amidst researching this, I feel like I saw someone recommended taking that rod out and cleaning it up.  Might need to do that while I replace the other parts.
It seemed to me the rod just needed to be removed and reset.
There was no cleaning involved as, other than some dust, it was fine (refer to the previous pics.)
Once I realized I had the wrong part, I replaced the old one and, quite frankly, it operated as well as the new one I installed.
To summarize, I would recommend removing and replacing the old torque rod before purchasing a new one. Still, the tailgate does need to be removed and set vertically for a proper fitment. A bit of a pain doing it by one's self.
OK, time to go back and reintroduce my head to the wall again ...
So I pulled the gate yesterday afternoon but got nothing replaced.  How in the world do you get the rod out?  Is it the bolts on the bottom of the tailgate?  I didn't investigate too much as I thought this would be a quick thing to accomplish while draining oil in my mower.  Long story short, I just put the tailgate back on and headed to the yard haha.
There is one bolt on the bottom of the tailgate on the passenger side. You would need to loosen it to allow the rod to be removed - then it just slides out.
Re-insertion is a bit of a trick and why the tailgate should be oriented vertically, on its side.
There is an access hole to aid in manual alignment.
Just be sure it's seated properly in the hole on the passenger side, and oriented correctly (there is an arrow on the rod bushing driver side end indicating such).
Re-installing the tailgate requires it to be lifted to a near vertical position to align the rod end on the driver side and then moving to 45 degrees to get the plastic bushing aligned with the hinge on the passenger side.
Edited by MikeBMW
    JimmyB4
    JimmyB4
  • Who's Online   5 Members, 0 Anonymous, 509 Guests (See full list)
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
    • Hello Guys I'm new to the form,         I just put a 7-inch Rough Country lift on my 2016 GMC Sierra 1500 with the 5.3 and I also put a Borla exhaust on it. But I noticed when I'm in park or in neutral and then I rev my truck up really quick there is a bad click noise and I think it's coming from the motor somewhere. Anyways I got a video of it I will attach below I was just wondering if you guys think its rod knock or lifter tick or something like that because I know the AFM kind of made the lifters weak on these trucks.       Thanks!!!!! RIP - Chevy 5.3 IMG_6043.mov
