1 hour ago, Pryme said:
Looks like that ACdelco didn’t perform very well according to that chart. I went with Amsoil severe gear
Severe Gear is outstanding. Going in my 24 this winter at some point.
When I found the stock fluid was low, like everyone who checks seems to be, I said screw it and drained it all and put in severe gear. Way I look at it is I got the initial break in done on the stock fluid and have good stuff in there now.
I had only a hundred or so miles on my truck when I saw I was low. Too lazy to swap out then. I'm almost at 10k miles so this winter will be a good time to swap out
Got to check my '24 H.D Rear axle fluid yesterday, at 4200 mi.. 1-1/4" below the fill.
Used a "Q" tip bent at 90 deg. as a dip stick.
XXXX'd I asked the dealer service manager, specifically to check this, before delivery with 23 mi. on the Od., and gave him a printed page of these blogs to boot.
I topped it off with the AC-Delco 75w-90 as in warranty. Giving receipt to my GMC dealer as had to do this quick on my time and expense, getting oil at closest GM dealer before close on noon Sat.
Thanks to all for the heads up, on these should be "Assumed" good to go new vehicle delivery checks.
  • Sad 1
Yeah it’s a total joke that these are low. You’re lucky that Qtip didn’t break off in there as those have a tendency to snap once they are already bent or kinked. Probably wouldn’t hurt anything in there but my ocd would demand I get it out ha
Thanks to @Pryme & others for bumping this thread from earlier this year. I just took delivery of my '24 GMC 3500 and will plan to check this weekend and let you all know what I find.
I didnt read the entire thread but has this been correlated to either of the factories? I see Pryme has a Silverado and Ive taken note of several GMCs so is this just Flint?
I thought the exact same thing 🤣🤣🤣
25 minutes ago, gemarsh said:
You all are checking the front diffs also, right?
Yup. Mine was not low thankfully. Much less issues with low front diffs than rears being low.
I think both factories
Yes that would be correct. As the gm factories just slap axles in from AAM.
Yeah they are filled at aam. So if anyone is to blame it’s AAM. Unless of course GM is giving them a value to fill and it’s slightly low. That cost savings would add up with how many diffs they fill.
You guys got me all paranoid so I went out and checked mine, and sure enough it was a full inch below the bottom of the fill hole on my 2024 3500 gasser. For those of you topping off (not doing a full drain/fill), are you just topping off with AC Delco 75W-90, or picking up just any brand from the auto parts store? About how much will it take to get it in the 0-10mm range?  I'm debating taking it to the dealer just so it's documented, but it's a hassle taking it in since it's 40 min away.
Edited by BuckWallace
I went to the stealership and made them give me some acdelco 75w90. I wouldn't mix unless doing a drain and flush.
I actually just went ahead and scheduled an appointment for them to do it. I'm at about 4,800 miles and have 2 free oil changes with the dealer (I changed it myself at 1k miles), so I just figured I'd take it in for an oil change and have them look at it tomorrow. Either way I'd rather have them document it and do it in case something happens later on (which I doubt).
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
