5 minutes ago, davester said:
alldata.com has the full service manual for your truck. SEMA25 for 25% off right now...
I have heard of that system but I am referring to an actual complete manual that is purchased and is downloaded and saved, a one time purchase rather than permission for a specified time to be allowed to view it.
30 minutes ago, Pryme said:
If I recall, the rear bolt was magnetic.
can’t help with specs. Newdude should be able to though.
I can't swear by it now but at the time I removed my check plug, I didn't get the impression it was magnetic to look at from what I am used to seeing with highway tractors etc with a bonded on magnet but I also didn't touch a steel object to the face of the plug to test it either. On older GM diffs so not a proper comparison but they typically had a magnetic donut of sorts that was placed in the bottom area of the diffs casting.
Thank you. Works out to a decent price for 1 year.
Edited by JW2024
Spelling
Just now, davester said:
gm doesn't license it for one-time purchases like that.
It would not be through GM, its some other source from what I gathered.
I have the alldata.com GM tech manuals for my 2024 Silverado 2500HD and also for my 2021 GMC Yukon. I find them to be an invaluable resource when working on my vehicles. I used them too on my previous 2019 GMC Canyon and 2022 Silverado 1500. Great info on them
And since this thread is about diffs. I'm gonna drop this video here.
Couple Highlights:
The diffs no long have drain plugs. (BOO! GM). The fill bolts are not magnetic. But the covers have a magnet attached to them.
The diff fluids have a range of "fullness": Rear Differential Approx. Minimum Capacity 3.17 quarts - Fill to 0.0"-0.4" below fill port. Front Differential Approx. Capacity - 1.9 quarts - Fill to 0.0" to 0.24" below fill port.
I used 75W90 Mobile Delvac front and rear. Been running great for several thousand miles.
T-Case is simple. Dexron VI fluid. Has both fill and drain plugs. Fill er up til it spills out.
Edited by fondupot
  • Thanks 1
Couple Highlights:
That was an excellently presented video that gave all the torque specs as well as where the magnets are located these days in the GM diffs, actual oil volumes experienced in refilling to the full level, cover bolt loctite use, oil level spec which has been discussed here and so forth. So it appears the front diff cover gasket is reusable even though GM lists it as a one time gasket. I had searched before on youtube but had not come across his video or your channel, this will certainly help anyone else on here with any unknowns.
I will say though I would caution the use of teflon tape on a tapered plug that goes into an aluminum housing and even more so if it has a thin walled aluminum boss that protrudes from the body of the aluminum cover, teflon in the tape form allows for a much lower torque value on the plug for how hard/deep its actually forcing itself into the tapered hole and has caused aluminum cases to crack at the hole if there isn't enough aluminum thickness to hold up to that stress. Using a liquid teflon or other non curing type plug sealer would be the safer bet.
Factory fill oil on diffs was 80W-90 non synthetic for many years and it was NOT the oil that made life any easier in our cold winters, horrible driveline drag and have used 75W-90 for many years now in various diffs from pickups to highway tractors. I figure with my climate challenges that I may as well stick with the 75W-85 in the front diff to allow just that much easier rolling resistance since GM approves of that fluid for the front but if I lived in a warm climate I wouldn't bother using the extra thin gear oil in the front.
Edited by Chuck FB
  • Thanks 1
Couple Highlights:
Nice video. Time to do my truck.
  • Thanks 1
I'm in South Carolina so 75W90 gear oil all year round doesn't hurt. I get your point about the teflon tape on the plugs, I've been doing it for years without issue. Thanks for watching.
Helminc manuals is what you want. $375 for my 2012.
I had looked that up before when I was wanting the full version of the operators manual and they didn't list a shop manual then, so now I searched again and still nothing other than the shorter or full version of the owners manual. If I go back to 2019 then they show a shop manual for that series of truck and although not any good for this truck, its 595.00 USD which is a whole other story of the gong show and rip off of my finally receiving the operators manual that in the states is 50.00. I paid around 230.00 Canadian if you can imagine for that manual because of dollar exchange and piles but a lot for importing as well as shipping. Not only that, the manual never showed up and finally I called Helminc and they traced it to Edmonton where the shipper threw the manual into the garbage because they couldn't figure out how to ship it to me because I have a rural address, Helminc was kind enough to wipe the slate clean and refund me at their expense. They then suggested I order the manual through the dealership which I did and they did receive it eventually. You have no idea how good you have it in the states where within mere days you can have a package plunked on your front step where it can promptly be stolen by the idiot following the shipping van around the city LOL.
So for now it seems there is no manual through that means and alldata would be the alternative and I have no clue what they charge for Canadians.
We live rural in the Colorado mountains, so i get the shipping fiasco.
    xdieselmechanic
    xdieselmechanic
  • Who's Online   2 Members, 0 Anonymous, 588 Guests (See full list)
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
