Is anyone running aftermarket shocks on a stock 2500 with 20” wheels? If so what are you running and how do you like them? Did you notice an improvement over stock?
I changed mine out for Bilstein 4600s.  Definitely noticed a difference, better control over bumps especially with a trailer on the back.  Wife noticed nothing.  😉
I put Bilstein 5100s on. They are a little softer feeling than the harsh Ranchos but I'm still on stock OEM garbage spec Firestones and I think they have a lot to do with transmitting the jolts. Hoping that with the 5100s and some better retail spec rubber that the truck lightens up from its shopping cart ride. Torsion bars and leaf springs and 7,000#s and what can we really expect though. With no coils on any corner I don't think it will ever achieve "pleasant".
I have also installed the B4600s.  Certainly noticed less 'movement' both loaded and empty.  I much prefer the ride over the stock shocks.  Huge difference when towing the RV.
So I'm in process of R&R'ing the stock Ranchos with B4600s. The rears were quick and easy to swap out and the right front (passenger side) looks to be straightforward. However the left front (driver side) looks like it may be a struggle because access to the top fasteners is partially blocked by both the inner fender liner (the pressed rat fur type) and a loom covered wire bundle that is zip tied along side the upper mount.  Though I was able to swap the rears out without lifting the truck, I will have to lift the truck and remove the front wheels to provide good access for the front shock swap. But I'm still concerned by the liner and wire bundle on the left side limiting top fastener access and making what should be an easy job into an aggravation. I have a diesel with dual batteries and the driver side battery blocks access to the fasteners from the top.
So my question to those who have gone before me, did you discover a procedure to minimize difficulty with the left front shock swap?
TIA
It looks worse than it is.  Get in there with a small pry bar and pry up on the wire loom.  It is fastened to the top of the bolts that hold the shock on with a cap that goes over the stud.  Once you get some room, you can get in with an open end wrench 1/3 of a turn at a time.
An open end wrench at 1/3 rev will be on the aggravating side of the experience.  Nevertheless thanks for the information regarding wire loom fastening. Hopefully it will be straight-forward and easy to secure the bundle after the shock has been replaced.  I need to use the pry bar to lift the inner fender up far enough to see the details of the stud caps you mention.
Cheers
It will all become apparent once you start prying.  Caps popped right back on for me.  Might be able to get a racheting box wrench on it.
Yeah ratcheting box end wrench will be what I use assuming the nut size is covered by what is already in my tool box.
anything will be an improvement.........ranchos fade fairly quickly anyway
king, fox, bilstein, and lift co proprietary brands.......
will probably just go Eibach as not wanting to dump big coin nor lift the truck, just something more controlled.......i have a box of Eibachs 2.0 pro truck lift series for 22 1500 trucks i never threw on, so will probably just trade them out, my neighbor has them and they ride really nice......
seeing how Bilstein is a digressive valved design i could see how they would do really well for towing though, i had a set on 1500 truck and they were good, small stuff was bit siffer but overall better than stock for sure
Edited by Dunn
Cheers
You don't even need to pry them up. Just start going with an open end wrench and the upward movement of the nut will force them off without damaging the plastic inner teeth. They'll pop back on after.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,096 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
