Long story short, I traded my 2020 trailboss for this truck and I’m pretty happy minus a few luxury items missing. I’ve noticed that slow speeds turning or where the truck bed shifts, I hear a pop and I don’t like it. I’ve read maybe just the leafs doing it and a piece of rubber will fix it? Also, I notice with no music on, truck running, I hear a hissing sound from the steering wheel…hard to explain but it changes when I turn the wheel and sounds like a hydraulic line!? Normal?? Any insight because I know dang well what the stealership will say and I don’t want to go through it all if it’s actually normal. Thanks
Steering is normal and even more normal if it has the digital assist steering.
Rear noise its likely the leaf pack.  "20-NA-022 Squeak, Grind or Clunking Noise from Rear Leaf Springs" and "21-NA-138 Squeak, Grind or Clunking Noise from Rear Leaf Springs" are the two bulletins on leaf pack noise.
Are those bulletins for 2020-2021 is that what the 20 and 21 stands for? What about 22+
Same with the hissing on my 2022 lt…..only hear it with no music on in park or at idle and reacts to steering wheel moving or once you start moving…..annoying but have had no issues with it other then being annoying
Well glad to hear it’s “normal” now to decide if I want to try and make the leaf noise go away with rubber strips or leave alone. I read some guys had the noise go away after 1000 miles or so and I’m only at 88 so I got time lo. The steering is so odd, mine is a Custom trim so I don’t think I have that digital assist but it’s definitely noticeable
The creaking in the rear goes away if the underside is drenched. Mine creaks when dry. 5100mi
The hiss noise you hear is the power steering system. Its a hydraulic system and the noises are perfectly normal.  You hear a howl noise at idle with no movement on the steering wheel. Noise changes when moving the steering wheel.  Totally normal.  6.6 gas comes with hydraulic power steering and hydraulic brakes.
Covers multiple years yes.
These are noisy trucks, every single T1 2500 I've had made that steering noise.....I am not concerned unless the basic function is affected.....but yeah my 1500s were much quieter vehicles ......
I have digital steering now and it sounds sane as my LT's DID AT HARD LOCK on steering
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
