5 hours ago, Laurent Kim said:
I started having an overheat issue and noticed that the radiator fan belt is cut.  Is that serpentine belt?  If so, is it covered under driver train warranty?
No. Just like hoses, belts, wiper blades, clutch discs, and brake pads. Considered wear items.
I would say yes, if that is your configuration.
I would find out what was the cause of it getting cut, before installing the new belt.
Definitely need to inspect the area around the belt to find out how it got cut.  Not likely covered under warranty, unless there was some other issue that caused it.  If the water pump pulley bearings froze up, it would cause a belt to rip.  In that case, if you are still under bumper to bumper it should be covered.
On 6/4/2023 at 9:22 PM, Laurent Kim said:
Need more info here.  What engine do you have, 6.6 gas or 6.6 Duramax?  Single or dual alternator?
OP profile lists 6.6 diesel. Single and dual alternators have a different fan belt? If so, do they have a different tensioner or water pump?
Honestly, I was thinking these were set up like the older Duramax with just one belt but I am wrong.
It appears these new ones are a two belt system, with the water pump/fan being on its own belt and goes to the balancer, the fan pulley and a dedicated tensioner.  And this is something that started with the 2020 L5P.  2019-prior Duramax including L5P are a single belt.
I have the Duramax with one alternator.
This is certainly not what we like to hear, Laurent Kim.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your truck. To do so, please send an email to [email protected] with ATTN: Laurent Kim/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
What year is the truck.
2020+ L5P has 2 belts, like the diagram posted.
2019 and earlier L5P only had one belt.
I'd take it and see if they can determine why the belt failed.
Gale Banks did a Youtube video comparing between the generations
It was posted on gm-trucks
https://www.gm-trucks.com/forums/topic/219613-whats-new-with-the-2020-l5p-duramax-watch-gale-banks-explain/?do=findComment&comment=2210996
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
