Hello, I am having an intermittent starting issue on my 2014 Sierra.  Right now, it will not start.  It clicks but does not start.  I can jump it, and it will start.  In fact, it will operate normally for a period of time and it will start after I stop it.  After the first time with the starting issue, I jumped it, drove to advance auto parts to have battery/alternator/starter tested, and everything checked out great (although he did say the starter test is not comprehensive and the starter could have a bad spot).  It ran fine for a day and a half with multiple trips.  Then it would not start again.  I jumped it, drove home, parked, stopped, and it started again.  Next morning (now) it won't start again.
When I turn on the truck, battery reads 12.8v or so with voltmeter.  After I try to start, it clicks, and then leave the power on, it reads like 9.6v in the truck and with the voltmeter.  But if I power off the truck and then turn the key on again, battery will read 12.8v again.
Any ideas of what it may be or other tests I can try?  Thanks in advance.
Also, this started happening the day I took my truck to a shop to have tires installed.  Also, a few weeks ago, I did the carplay upgrade where I replaced the radio and HMI, but it had been working fine since then.  But the infotainment system is also not coming on when the power is on (but this may be related to theft deterrent or something else?) and it also did not come on yesterday after I jumped my truck - the radio was on 87.9, but the infotainment was not on and I could not turn the radio up or down or change channels.
I’ve had bad batteries cause that issue. My battery in my lawnmower is doing that now. A bad battery in my old truck made the transmission shift funny and sometimes would lock in tow-haul. It may not be related but a new battery fix the problem going on two years now.
Thanks so much!  It was the battery!  Manufactured in 2017.  I think the heat finally killed it.
This is why I replace my batteries every 5 years regardless of how well it's cranking or whatever. They can fail with no warning and never in your driveway.
I do the same beetle, makes no sense to me to wait until it won't start or other electrical problems due to bad battery.
You are going to buy one eventually so why wait until its a problem.
