Decided to put a fart box on it. Gives it mini diesel vibes, and can hear the turbo a bit more. 3" in/out Black Widow Widowmaker. Still have the resinator also.
Finally swapped all the chrome badges out with black. So much nicer! And then ordered the Banks iDash and PedalMonster today.
I love the 5100s but already itching to snag some deals this week on coilovers and an upper arm. Definitely gonna pick up some A-pillar lights though.
Got the iDash and PedalMonster in. PedalMonster is a blast!  Hopefully the A-Pillar lights come in this week so I can go pick those up. Went with SDHQ mounts and Baja Designs XL Pro's. Gonna just run a rocker in the blank plug where the trailer brake controller goes.
Did the widow maker really change the exhaust sound enough to justify the muffler swap?
Yes. After going with just the delete, it made a huge difference in not only tone, but reducing drone. This is just at idle w/o any load on it.   Before the BW, Wife never drove it, now I can't get her to use her own car.
Edited by Vincej138
A-Pillar lights came in. Should get them on next week. Think im gonna do a rocker in the blank plug where trailer brake normaly is.
Baja Designs XL Pros
SDHQ Mounts
Got the lights on and wired. Routed through passanger side gromet/nub. They are just on a small round rocker in the blank plug where trailer brake goes.
As much as I do like the 5100's, I got itchy and pulled the trigger on some Fox 2.5" coil overs and 2.5" rears with Dirtking BJ uppers for the extra travel. Really just wanted the mid-travel setup and the ability to fine tune the stance/ride and then plan for deavers in the future and finish the front off with their lower arms.
Since I'm on a 3" spindle, I don't need the full pre-load that comes on the Fox's (3.5" of lift) So i picked up the springs that are used on the 0-2" lift versions (16" / 550's) and will swap those over. I'm only looking for  1-1.5" more than now and will add a 1" shackle to the rear to give me about 4.5" in front and 1" in the rear to be about 1" nose high wen everything settles.  Right now im dead nuts level with the 5100's at stock height and the 3" spindle. May take the swaybar off and see how that feels as well.
For anyone else with the 2.7L, Fox is the only one who uses a 550lb spring. King and the others are 650's so the ride should be better for us turbo lovers. I got the motion ratio and preload #'s from Fox so i can adjust before putting them
Took tomorrow off to finish the speakers and intake/charge pipes. Pics to come.
Hows your mileage been with the 2.7L and those big ole tires?
Truck looks sharp.
Truck looks sharp.
Not as bad as I expected honestly. Highway im around 20-21 still when flat. Hills it drops obviously. Around town its about 16/17. I just idle a lot when waiting for kids in pickup line ao its kinda skewing it. Im hoping the intake and pipes gets me an mpg back.
It can still spin em though!
Intake on.  I ran into a snag with the Intercooler pipes. Looks like AFE may have changed their adapters. It seems like the clips can go internal on thr adapters vs external as shown on install sheet. But i just want to make sure so i reached out to AFE with some photos. The o-rings are a bit undersized looking too.
Got the Fox's and DK upper arms on today. Brought the front up about 1.5 which is about where I wanted.had to adjust preload a few times to get it right. She can stretch her legs decently now.
20240412_101147.thumb.jpg.872f2a2060f8edb6bae88958ce44dd35.jpg20240412_181755.thumb.jpg.a1b30a80ec14883040cab561deb2b224.jpg20240412_181810.thumb.jpg.c11b4c0552d6f5885c541fd9c7df4d5f.jpg
Added some Dirt King Cam Tabs and UCA Caps, Lasfit Floor mats and Talon's Garage Skid plates to it.
Edited by Vince Judy
    TopBo
    TopBo
  • Who's Online   6 Members, 0 Anonymous, 843 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
