Hello all--
Former Ford trucks owner for the past 15 years. They were 250/350, 7.3 diesel, 460 V8, and V10.
Also owned:
New 2005 Ram Cummins....lost torque converter at 75K...sold it and moved onto the 7.3 diesel Ford.
New 2010 Tundra...very reliable
Fords were all purchased used
Purchased my new GMC yesterday....man is it NICE! Drove 300 miles round trip to get it.
Looking forward to my GMC ownership. My hopes are that it is as reliable as my previous Fords, as they were ALL very reliable and easy to work on. I perform all of my own maintenance.
This new GMC met all of my requirements....
White
4X4
Crew
Gas
Short bed
Payload (4225#)
No high end options
What do I use it for?
Towing a 7500# Travel Trailer
Towing a 2500# Fishing Boat (freshwater)
Potential future over head camper...maybe an 8'-8.5', nothing too large or too heavy
Camping, general truck use for home projects, etc.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
